90 yj 4.2 wont start!! Help!! Please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 90 yj 4.2 wont start!! Help!! Please
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 02-17-2015, 12:55 PM   #1
jb19d
My 1990 Jeep Wrangler YJ 4.2 won't start, turns over but sounds weak. So far I have replaced carburetor, (weber), spark plugs, distributor cap and rotor, fuel filter, starter, starter relay and ignition control module, when I put the new starter on it would try to start for a second then nothing!!! Please help before I replace every part in this engine!
jb19d is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 01:51 PM   #2
Que89YJ
Welcome to the forum. If you get a chance please fill out the profile to help figure out what you are dealing with. You said its turning over but sounds weak? Like it is struggling to spin the engine?
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 02:29 PM   #3
Jeepsr4me
Battery is not in your list of replaced thingss
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 02:47 PM   #4
dancytron
Bad battery cables or bad connections. Especially the main ground cable.
dancytron is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 02:52 PM   #5
jb19d
Yes it is struggling to turn over. I have put a full charge on the battery before I guess I could swap out the cables?
Unread 02-17-2015, 03:15 PM   #6
jbolty
jbolty's Avatar
Why would you change any parts until you know what's wrong with it?
I would begin by testing the battery. Does it spin normally if you jump it from another vehicle? What about pushing or towing to start it; is it a standard transmission?
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 03:18 PM   #7
Jeepsr4me
Cables can corrode on the inside and the clamps or terminals can get a coating that shields it from making good contact.
I take a knife and cut the inside of the battery terminal and the lug on top of battery till it is nice and shiny
Unread 02-17-2015, 04:11 PM   #8
mickcollinsb16b
mickcollinsb16b's Avatar
i agree with all previous posts to check out your battery cables before sending anymore cash on other parts. cheap and easy to do that is where i would start.
RoknRoll, beer & Jeeps
mickcollinsb16b is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 05:12 PM   #9
jb19d
The battery cables are installed. Same issue? Battery is good o had it checked and charged it for 24 hours. Anyone else got any ideas? Compression maybe?
Unread 02-17-2015, 06:18 PM   #10
Jeepsr4me
Try jumping the relay at the solenoid...
Unread 02-17-2015, 08:11 PM   #11
Que89YJ
It is battery cables or starter.
Unread 02-17-2015, 08:15 PM   #12
Que89YJ
You can use jumper cables to bridge the wires from the battery to the starter to eliminate the wires. Do both positive and negative. If that doesn't change it then jumper to another battery of a car and see if it's any better. If both of those are good then you need a starter.
Unread 02-17-2015, 09:07 PM   #13
YJ8
When I trouble shoot I make it easy-- You need three things for the motor to run-- Fuel, Spark and Compression. Figure out which one you are missing and you are 90% finished with diagnosis.
If it does not turn over the post above have you covered.
YJ-8
YJ8 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 12:15 AM   #14
bergovoy
like the above poster said you need to diagnose things before throwing parts and money at it and praying that it will fix whatever problem exists.
to start the diagnosis, I usually try some quik start fluid or brake cleaner/parts cleaner, and give a short squirt into the carburator or air intake assembly, then try starting the motor..
if the motor tries to start, but doesnt stay running, then your problem is a fuel related problem... if it doesnt try to start then it probably is an electrical problem...
so, go ahead, give it a shot and report back
bergovoy is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 06:49 AM   #15
jb19d
I have already done the starting fluid, and it still sounds exactly the same. What about timing?
