'90 YJ 2.5l rebuild to !Diesel! Newbie Help! - JeepForum.com
post #1 of 10 Old 03-03-2011, 05:16 PM Thread Starter
MalcolmM
Simply stated. Recently bought my '90 YJ with 86k mi. Want to get rid of my '05 SRT-10 and my '99 Firebird and concentrate on one all-around monster. i.e. bestial Diesel Jeep!
I'm planning to rip up the YJ (which runs perfectly fine) and part it out, but keep the frame to work from for this build.
Unfortunately that's about as far as I get. I really want this to be a project that I do, and I've got some tech-savy friends that can help me. But I need to know where to start dumping my money in order to get this build going.
I figure the bottom up is the best way to go; especially considering I don't have a great garage to work out of.
But I would like to know a little about some diesel engines you'd suggest as well as where I could get the conversion kits (or what I have to cut/weld/mod). I also don't know how the weight will translate into required axle support, or any of that as a matter of fact.
So let's just assume I'm a super dummy and would like some advice despite my staggering incompetance!
Thanks in advance for all your help/critisim/etc.
MalcolmM is offline
post #2 of 10 Old 03-03-2011, 05:29 PM
YJay92
Cummins 4bt, google 4bt into a YJ and you will find lots of writeups. Thats the next engine going in my YJ.
1992 YJ, 4.0, auto, HP D30 w/TJ chromolys, 8.8 LSD, 4.10s, AA SYE, Tom Woods shaft, 5" lift, 35" MTZ's, 12k winch, Mark VIII fan, 136 amp alternator, TJ flares, custom snorkel and rock rails, no track bars or sway bar
YJay92 is offline
post #3 of 10 Old 03-03-2011, 06:59 PM
Noltz
YJ Wrangler
Yep, BT4 is the diesel of choice. Mercedes made some good old diesels too. They were 300D models. If you can have your trans-of-choice adapted, they're bulletproof motors and a lot cheaper.
All said, you're gonna be bored with a diesel from an SRT-10. Buddy had a BT4 in his TJ, and it made a bit more power and doubled his mileage... but it wasn't mind-blowing.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #4 of 10 Old 03-03-2011, 07:18 PM Thread Starter
MalcolmM
Bored? Never!
I know I can't expect the same, but everything about a Jeep is so much more appealing to me. The turn radius alone is nothing to scoff at.
Park a four door SRT-10 50 times and tell me you don't miss your Jeep!
But I'm just looking for a daily driver with a little pick-me-up and the ability to do pretty much anything. The MPGs will also be a big plus, as my Viper gets 10.7mpg based on my fuel monitor.
We'll see how things go. I may keep the SRT-10. But between the Jeep (once diesel), the truck, and my sport bike, I'm pretty sure there won't be much I can't do.
Thank you both for the input and help! I feel like I've learned a shoot ton already!
MalcolmM is offline
post #5 of 10 Old 03-03-2011, 09:09 PM
H3RTCH
Live Free or Die.
H3RTCH's Avatar
You need to check out this website. More information than you can shake a stick at, and there are a few jeep guys on there who swapped them into YJs already, so there is some precedence to follow.
http://www.4btswaps.com/forum/index.php
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
post #6 of 10 Old 03-03-2011, 10:30 PM
Douglas S.
Cummins B3.3T
Far better for a Jeep than the 4bt.
You can adapt it to the ax-15, it doesn't weigh 800 pounds, and it puts out plenty of power.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #7 of 10 Old 03-03-2011, 10:36 PM Thread Starter
MalcolmM
Ignorance is not always bliss :/
Would it be awful to ask what would make the 3.3 a better candidate than the 4bt?
Is it only the weight?
I suppose I should look it up, but I wonder what the stock power vs reasonably increased power gain is different in the 3.3 vs the 4.0...
Or is there some other efficiency issue I'm too new/inexperienced/toolish to realize?
As I've said I plan to use the time I have to make this project a success. Which means figuring out exactly what I want the end result to be before I start buying.
Thank you!
'90 YJ awaiting diesel conversion
'05 SRT 10
'06 CBR600F4I
'99 Firebird (Trying to sell)
MalcolmM is offline
post #8 of 10 Old 03-03-2011, 10:37 PM
Douglas S.
See my edit above. A B3.3T is a Cummins turbo-diesel. Stock it has 85 hp, 215 ft lbs. It can be easily tweaked to 300+ ft lbs and 130 hp with minor adjustments and modifications.
Approx. 35-40mpg in a YJ.
post #9 of 10 Old 03-03-2011, 10:43 PM Thread Starter
MalcolmM
Dang, you saw my stupid post before I could edit it.
Sounds like a great deal as far as mpgs at least.
I imagine it will then still have a comprable effect on the drivetrain & axle?
If you're tired of answering questions I'm sure I could use a 4bt build from the website only with a 3.3t in exchange as far as engine right? Oh, and are the engines comprably sized so as to fit the same chevy engine mount kit?
Thank you again!
'05 SRT 10
'06 CBR600F4I
MalcolmM is offline
post #10 of 10 Old 03-03-2011, 10:46 PM
Douglas S.
It will be easier on the drivetrain than a 4bt.
Instead of me trying to answer questions I'll show you where I learned what I know about them.
Warning: long read
http://www.dieseltruckresource.com/dev/b3-3t-jeep-yj-t112807.html
diesel , newbie , swap , YJ
Newbie- 2.5l rebuild questions... moparpower1985 YJ Wrangler Technical Forum 3 02-09-2010 02:45 AM
Diesel conversions/crate diesel engines for a TJ 4x4VT TJ Wrangler Technical Forum 3 06-04-2009 03:44 AM
Newbie question on weber 32/36 rebuild pge27 YJ Wrangler Technical Forum 0 02-18-2009 08:58 PM
clean diesel in 2009 and a new 4 cyl diesel in the works (maybe) 79CJ7Renegade JK Wrangler Technical Forum 0 06-21-2007 01:29 PM
jEEP GIVE US THE DIESEL HECK IF THE hUMMER H3 HAD A SMALL DIESEL IT WOULD BE NUMBER 1 4.0v8eater JK Wrangler Technical Forum 22 08-02-2006 12:10 PM
