90 yj 2.5 to 92 yj 4.0 swap? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 90 yj 2.5 to 92 yj 4.0 swap?
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 08-30-2014, 05:04 PM   #1
flippinjeep
ok so heres the deal......ive got a 90 yj that had a 2.5 motor
we removed 4 cyld motor moved motor mounts got the 4.0 sitting in the engine bay.....and then the wiring
I have the 4.0 harness hooked up to the motor and seams to plug into my bulkhead wirng harness is that correct? or do I have to move pins?
alos the 4.0 harness goes into the bulkhead in the center but my old harness has the same set up but a different plug what can I do about that?
ill try to get some pics up soon
flippinjeep is offline   Reply With Quote
Unread 08-30-2014, 05:40 PM   #2
YJ4LIFE
you'll probably have to move pins. get the factory service manual for the 90 and the 92. start figuring out what goes were.
do your research before you start. Its not that hard just time consuming. You need 5 wires to fire but you have a lot of duplicates between the two harnesses. You'll end up merging the 2 into 1.
I can email you a copy of the exel sheet I was working on if you want.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote
Unread 08-30-2014, 05:51 PM   #3
flippinjeep
if you could email them to cmayranen@yahoo.com that would help me out a lot
Unread 08-30-2014, 06:30 PM   #4
YJ4LIFE
sent
Unread 08-31-2014, 06:41 AM   #5
flippinjeep
thank you
Unread 08-31-2014, 10:53 AM   #6
orestes107
Hey. Looking to do the same thing. Could you email to xerxes3235@gmail.com.
Thanks!
orestes107 is offline   Reply With Quote
Unread 08-31-2014, 02:49 PM   #7
flippinjeep
sorry guys but im still lost here.....5 wires to fire
which 5 wires from the 92 yj harness need to be moved/spliced into my 90 yj bulkhead connector?
Unread 08-31-2014, 03:12 PM   #8
flippinjeep
since the engine hardness is also from a yj with it be plug and play?
Unread 08-31-2014, 03:30 PM   #9
YJ4LIFE
Thanks!
sent
Unread 08-31-2014, 03:39 PM   #10
YJ4LIFE
lots of info on google.
http://www.jeepforum.com/forum/f12/5...l-swap-357865/
You need ignition to turn the jeep on
you need fuel pump relay active to turn your fuel pump on
you need the starter to turn the engine
you need battery to power everthing
I know that's 4. I Don't know where the 5 came from. :P
Unread 08-31-2014, 05:38 PM   #11
flippinjeep
ok I got it started by adding 1 wire for the ignition and using starter fluid cuz im not getting fuel......I hot wired the fuel pump and it starts right up
on b4 it says for 2.5 only and says fuel relay and my old motor was a 2.5 do I add power there for the fuel pump?
Unread 08-31-2014, 05:42 PM   #12
flippinjeep
e4 and d4 already had power on my hardness
g5 had ign power
d5 was empty so I added a wire and gave it ign power
and my jeep started when I put starter fluid in the t.body..........but need to figure out fuel pump relay
