90 wrangler yj idle problem - JeepForum.com
post #1 of 5 Old 04-27-2008, 07:52 AM Thread Starter
wrangleryjman
hey i have a 90 wrangler 4.2 straight 6 and it wont idle everything above 2500 rpms is ok its the low end thats the problem. i have cleaned the idler tubes before and that was the problem thats prob what the problem again but even when i do that it doesnt idle steady it goes up and down. is there anything i can do to get it to idle better
wrangleryjman is offline
post #2 of 5 Old 04-27-2008, 10:07 AM
timatoe
timatoe's Avatar
Get familiar with this site.. http://home.sprynet.com/~dale02/list.htm
Do this .. http://jeep.off-road.com/jeep/articl....jsp?id=277064 OR Buy this kit .. http://jeepcarterbbdcarb.com/kit.html
I did the kit and haven't had a problem since. If you can do the Nutter Bypass.
timatoe is offline
post #3 of 5 Old 04-28-2008, 02:42 PM
BlackSheep92
Excellent post
"Courage is not the absence of fear. It is the willingness to move forth despite it's presence"
BlackSheep92 is offline
post #4 of 5 Old 04-28-2008, 03:42 PM
ctm
I refer you to Mike Romain's posts regarding how the evap canister purge line can give inconsistent idle:
http://groups.google.com/group/rec.a...b145ada4f4c5f2
You can also search the CJ forum on this site for other similar posts.
ctm is offline
post #5 of 5 Old 04-29-2008, 05:52 AM
vadslram
I fought with mine and could never keep the idle clean for more then a week. I replaced the stocker with an MC2100 and I havn't messed with the thing since I put it in. My milage went up too.
vadslram is offline
Idle Problem with 1999 Wrangler dcddan TJ Wrangler Technical Forum 4 12-10-2008 02:09 PM
wrangler won't idle skeeballhead TJ Wrangler Technical Forum 6 05-05-2008 02:25 PM
89' Wrangler YJ 4.2L Idle Troubles horseman YJ Wrangler Technical Forum 9 08-09-2006 06:43 AM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 07:50 PM
90 Wrangler 4.2six won't idle Wingryder YJ Wrangler Technical Forum 5 01-25-2003 09:26 PM
