'90 Wrangler won't pass smog! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > '90 Wrangler won't pass smog!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 06-16-2013, 12:41 PM   #1
runhot
I have more than 6k invested in my Wrangler, new engine, trans, top, brakes, radiator, hubs, battery, carb, etc. and it still won't pass California smog. I have had the 02 sensor replaced, cat converter was changed out 2 yrs ago, it has a new carb, timing set, new plugs, wires, etc and it comes close but still won't pass smog. I have all this $ invested for use in snow area where I will be living. (my life could depend on this jeep) I really need to use it! My mechanic (who has never let me down ever) can't seem to figure it out. Any help would be appreciated!
runhot is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 01:06 PM   #2
jbolty
jbolty's Avatar
post the numbers
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 02:53 PM   #3
runhot
Emissions
I will have to get them from my mechanic but as I recall he said the hydrocarbons were the problem. (I thought this was odd because the converter isn't very old)
Unread 06-16-2013, 05:50 PM   #4
Old4X
1990 CJ7
How did he set up and tune the carb?
Have you checked for blocked idle bleeds, happens even on brand new carbs with the bad gas sold these days.
Is your mechanic using an exhaust gas analyzer to set it? This is a must where you are, can't be guessing on it.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 06:03 PM   #5
youngjeepr
A TEMPORARY fix is run your tank down to about 1/8 tank premium then add 4 quarts of rubbing alcohol it will much run cleaner after you pass go full up with premium
[COLOR="Red"][/COLOR][SIZE="5"][/SIZE]88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
[URL="http://www.jeepforum.com/forum/f319/"][SIZE="4"][COLOR="Red"][CENTER][B]Utah Jeep Crew[/B][/CENTER][/COLOR][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f22/youngjeeprs-build-take-2-a-2012985/"][COLOR="Red"][U][B][CENTER][SIZE="4"]Build Thread[/SIZE][/CENTER][/B][/U][/COLOR][/URL]
youngjeepr is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 06:05 PM   #6
youngjeepr
The 5.7 in my jeep just has cherry bombs and my HCs are 80 when I add rubbing alcohol and 140 without. I also have a fairly lopey cam.
Unread 06-16-2013, 06:08 PM   #7
Old4X
1990 CJ7
Better check it with a sniffer first.
Rubbing alcohol has water in it.
Unread 06-16-2013, 06:17 PM   #8
youngjeepr
Not enough to harm your engine in that small of amount... But I would check how your carb is tuned and read your plugs. And possibly put some hotter plugs in
Unread 06-16-2013, 06:23 PM   #9
jollyroger1
If it is really close creating a small vacuum leak can sometimes work ,it did for me last year
jollyroger1 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 11:17 AM   #10
runhot
Thanks eveyone, it finally squeaked by with 87 on the hydrocrabons!
Unread 07-20-2013, 11:25 AM   #11
runhot
Turns out the new carb had to be tossed (ouch) it didn't have the recall mods required for california, That meant another $340 to rebuild the old one. My mistake for buying a new Rallye brand Carb online. (warranty already expired waiting for engine and trans rebuild)
Unread 07-20-2013, 11:28 AM   #12
runhot
The problem was hydrocarbons at 15 mph... who drives 15 mph anyway!!!
Unread 07-20-2013, 07:35 PM   #13
rocketboy
I'm waiting for a new carb to come in to try to pass here in Texas.
I'm interested in this rubbing alcohol thing. If I understand what was posted above, I leave 1/8 tank of premium in and then add 4 quarts of rubbing alcohol? 4 QUARTS? What comes in the drugstore is pints. Do you really mean quarts or do you mean the pint bottles? If you mean quarts, I could get a gallon at the hardware store. But I don't want to add too much...
rocketboy is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 07:46 PM   #14
youngjeepr
I meant pints sorry. And the rubbing alcohol trick should just be used as a temporary fix until you can fix it properly... Also after you pass the test fill Your tank with premium fuel again.
Unread 07-20-2013, 07:55 PM   #15
rocketboy
OK cool, thanks! Understand, I don't want to run like that all the time but I just need to pass the test. It's the last time, too. Next year she'll be 25 and exempt here.
smog
