90 wrangler gear oil? - JeepForum.com
post #1 of 11 Old 04-25-2012, 11:23 AM Thread Starter
90wranglerguy
Hey I just bought my first jeep, its a 90 wrangler sahara edition with the 6cyl and 5spd trans. I went to Oriellys to get gear oil and they gave my synthetic 75w90. Is the synthetic required or could i just get regular 75w90? Thanks.
90wranglerguy is offline
post #2 of 11 Old 04-25-2012, 11:31 AM
pete1991YJ
For the trans, the factory recommended straight 30-weight motor oil. There was a dealer service bulletin update about it. Other than that, it doesn't seem to make much difference either way between synth and regular. It waas designed for regular but either way will work.
BTW welcome to JF, you've just found one of the best jeep sites anywhere!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #3 of 11 Old 04-25-2012, 12:07 PM
pasinbuy
10w-30 motor oil
pasinbuy is offline
post #4 of 11 Old 04-25-2012, 12:15 PM
bogleparsons
75w90 is fine for the axles.
10w30 for the 5-speed transmission.
ATF for the transfer case.
5w or 10w-30 for the engine.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #5 of 11 Old 04-25-2012, 02:44 PM Thread Starter
90wranglerguy
Thanks guys I appreciate the help. So the transfer case takes ATF and the trans uses 10w30?
post #6 of 11 Old 04-25-2012, 02:51 PM
94chb
yes
94chb is offline
post #7 of 11 Old 04-25-2012, 09:04 PM
tomemt
Just curious is this the same for all YJ's
tomemt is offline
post #8 of 11 Old 04-25-2012, 09:11 PM
94chb
same for all EXCEPT if you have a automatic trans, then you put atf +4
94chb is offline
post #9 of 11 Old 04-25-2012, 09:35 PM
rodgers3
dang i need to buy 10 w 30 for my transmison then :/ running synthetic in everything, i also just bought a 92 yj changed the engine oil today checking the axles tomorrow
side note....if its an auto you payed to much
rodgers3 is offline
post #10 of 11 Old 04-25-2012, 09:56 PM
94chb
my auto never gave me any problems, ive swapped to manual (ax15) and now the trans is out of the jeep for the 3rd time since the swap 1 year ago
make sure you also have atf in your transfer case.
94chb is offline
post #11 of 11 Old 04-25-2012, 11:21 PM
TMSquy
If the ax5 or ax15 was built properly and you can customize the synchronizers so that they get more lubrication and less preload, you can in fact run 75-140 in it. its what ive been running since the day i learned to drive til now. Dana specifies 75-90 HP is recommended for front difs. rear diffs they want 80w-90. i run 75-140 in everything except the transfercase. i use atf+4 in the transfercase.
TMSquy is offline
gear oil , oil , wrangler
1997 tj wrangler Gear grinding when put into 3rd gear JeeperTJ19 TJ Wrangler Technical Forum 3 12-28-2011 06:13 PM
89 wrangler studders 2nd and 3rd gear dvmetzler YJ Wrangler Technical Forum 1 09-14-2010 09:16 PM
Pinion gear on a 98 wrangler rasa TJ Wrangler Technical Forum 4 09-10-2008 07:42 PM
93 Wrangler dumped 5th Gear TightPenny YJ Wrangler Technical Forum 3 08-10-2007 09:19 AM
Gear in my 05 wrangler 93yjeep TJ Wrangler Technical Forum 4 03-01-2006 09:10 AM
