90 with Electric Fuel Pump Question - JeepForum.com
post #1 of 6 Old 08-10-2011, 09:22 PM Thread Starter
spawnofsatan
So I took my gas tank off to replace rollover Valve and the jeep was setting for about 1 month tonight I put everything back together fuel pump is working but is not pick up fuel do I have to prime it first? thanks.
FYI.
I check the pick up and return line and everything is correct.
spawnofsatan is offline
post #2 of 6 Old 08-10-2011, 09:52 PM
cevans87
1992 XJ Cherokee
sounds like you have the lines criss crossed... and no you don't have to prime it first
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #3 of 6 Old 08-11-2011, 02:48 AM Thread Starter
spawnofsatan
I took the fuel tank off again and remove the pick up line and return line put both in gas(small bottle) and not picking up fuel. confuse here.
post #4 of 6 Old 08-11-2011, 03:50 AM
Mark05059
the pickup tube is in the tank. Both lines that are external would pull no fuel from a bottle. Its possible that the bottom of your pickup tube sock is missing and not touching the fuel in the tank to pick it up. Not to be an a-----e but the pump runs when you turn on the key correct?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 6 Old 08-11-2011, 05:02 AM Thread Starter
spawnofsatan
Orig my 90 had a Mechanical fuel pump I replace it with electric one (External) mounted in the frame next to the fuel tank so I figure that if I put the pick up ad return line to see whats happening.
post #6 of 6 Old 08-11-2011, 07:14 AM
raynmaker
elect pump on the frame might need primed. Mine didn't but I was lucky. Mech pumps don't need primed just lots of cranking to get fuel the 12 feet to the pump.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
Electric fuel pump help nala YJ Wrangler Technical Forum 2 05-19-2010 03:54 PM
electric fuel pump murilstone YJ Wrangler Technical Forum 4 04-21-2010 04:52 PM
Electric fuel pump. bella mia YJ Wrangler Technical Forum 1 04-18-2010 12:39 PM
electric fuel pump??? skier518 YJ Wrangler Technical Forum 6 05-09-2009 07:56 AM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 12:12 PM
