90 to 91 Engine Swap - JeepForum.com
post #1 of 7 Old 05-01-2011, 02:55 PM Thread Starter
Schaef81
Ok guys here's the scoop. I have a 1990 yj with the 2.5 TBI engine. Basically the engine blew and I found a 91 mpi engine for 300 bucks. Bought the 91 engine with the plan of keeping it a tbi by swapping intake/manifold and all other accessories.
Over easter weekend when I was home from school I successfully got the old engine (90) out and the new engine (91) in. The only thing I kept on the 91 engine was the flywheel which to my understanding needs to be done. Now that the engine is in and everything component is hooked up it cranks but doesn't turn over.
My hunch is that the flywheel from the 90 engine needs to replace the 91 flywheel because the cps isn't picking up the 91 flywheel because it is made for 87-90 2.5l TBI engines. Is this a wrong assumption or could it be something else? As for everything else goes we carefully marked the distributor from the 90 and replaced the 91s distributor from that of the 90 to the correct position.
Any help is appreciated since I very much want to get my jeep on the road with summer coming up.
Schaef81 is offline
post #2 of 7 Old 05-01-2011, 03:08 PM
minimudder
1987 YJ Wrangler
I feel for ya man. My 87 to 91 swap has been an ongoing battle for 3 years. I work a little And get mad and outta money and stop but I finally have it running. I didnt stay with tbi and I forget
Why now. But it was probably a big mistake. I have so many little gremlins it took forever to figure out. So I would suggest calling a parts store and seeing what the difference is between the two flywheels. No CPS will def not let her run. Just double check all the major things for it to run gas air spark. And after that the flywheel would be a good place to start if you have it already. Seems like a good idea. Maybe someone on here knows a way to bypass the CPS just to get spark to figure out if the CPS is the reason you aren't getting it. Sorry I just rambled on and didn't probably help
Much but best of luck to ya!
87 YJ, shackle lift, 33's, currently swapping to a 91 2.5
------------------------------------------------The following errors occurred when this message was submitted:
The text that you have entered is too long (2001 characters). Please shorten it to 2000 characters long.
minimudder is offline
post #3 of 7 Old 05-10-2011, 07:46 PM Thread Starter
Schaef81
Ok for all that are interested. I swapped the flywheel from the 90 and adjusted the timing and the engine fired right up. So for future references you must keep the flywheel with the fuel system you are keeping. TBI 87-90 flywheel and MPI 91-95 for the 2.5 liter. Thanks to all who have helped me. Its good to finally have the jeep on the road!
Schaef81 is offline
post #4 of 7 Old 05-10-2011, 08:59 PM
MoparFreak69
Just so you know, there isnt any sensor in the distributors of the 4 bangers, they are simply a way to direct the spark. All timing is handled by the CPS and the ignition module, turning the distributor will do nothing. Glad to hear you found the problem, I was going to suggest swapping the correct flywheel onto the motor. 2 completely different systems, TBI is old school Bendix while MPI is Chrysler. Entirely different signals between the 2 systems.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #5 of 7 Old 05-10-2011, 09:03 PM Thread Starter
Schaef81
Yeah man, made a ton more work for myself not switching flywheels when the engine was out of the jeep. Took the most part of 2 days to get everything together along with figuring out the nippodenso alternator setup with the renix. Needless to say though I'm extremely happy with the swap.
Schaef81 is offline
post #6 of 7 Old 05-10-2011, 11:03 PM
lclark2074
the extra senser that comb on a 6 banger is for injectors not for ignition
night crew 226
lclark2074 is offline
post #7 of 7 Old 05-07-2013, 09:10 PM
shnitzle
different flywheels
in the bottom picture the left one is from an 88 the right from a 92
shnitzle is offline
2.5l , engine , no start , swap
My Jeep ate its engine ! - need advice on engine swap... ymibuyingmore YJ Wrangler Technical Forum 5 05-03-2011 03:31 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
1984 CJ7 6 cyl 258 engine swap into 1988 wrangler with 6cyl 258 engine? xavier27 YJ Wrangler Technical Forum 0 07-29-2010 02:08 PM
some ?s on engine swap or trans swap mdf27 YJ Wrangler Technical Forum 3 06-07-2008 09:24 AM
