90 2.5l no fuel - JeepForum.com
post #1 of 7 Old 02-02-2013, 08:23 AM Thread Starter
boatsandhose
90 2.5l no fuel
So I just got done replacing both u joints on my rear drive shaft and replacing the yoke on the rear axle. In preparation for installing my metalcloak bumper I started to take off my old crappy fog lights. I figured out the po wired them into the radio so no radio now. I took it for a ~15 minute ride and all was good. Parked it and 30 minutes later I go to leave for work and it won't start. She will catch with starting fluid but won't run. I'm not getting any fuel. Is there any possibility that the radio/ fog lights were wired into the fuel pump so when I cut the fog light wire it shut that off too? I'm stumped. Gas gauge says I have a 1/2 tank. Any help please?
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #2 of 7 Old 02-02-2013, 08:26 AM
Que89YJ
Check your fuseable links on the solinoid on the firewall and the fuel pump relay on the passenger fender.
Que89YJ is offline
post #3 of 7 Old 02-02-2013, 09:59 AM Thread Starter
boatsandhose
Ok I think I found my problem. This is in the middle of the firewall. The wire marked "A" has torn. Would this be my problem and how would I go about replacing it?
post #4 of 7 Old 02-02-2013, 03:39 PM
Mark05059
go to the local auto box store and get some weather pack terminals... If you have enough length just strip and crimp.. if not enough length... lengthen the harness with new wires and then strip and crimp.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 7 Old 02-02-2013, 03:51 PM Thread Starter
boatsandhose
Thanks couldn't find what they were called. What's the wire that is brought Ken supposed to do?
post #6 of 7 Old 02-02-2013, 04:16 PM
Mark05059
I cant tell you because I cant see what its running.. You obviously need connected though
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #7 of 7 Old 02-02-2013, 04:22 PM Thread Starter
boatsandhose
Yeah I didn't have time to check into it thanks!
