'90 2.5 bucking / cutting out - JeepForum.com
post #1 of 11 Old 08-20-2013, 10:15 PM Thread Starter
ken98k
1974 CJ5
My 1990 2.5 yj accelerates and runs like a top going down the the road but when I try to maintain a slow speed like on a logging road it bucks and feels like it's cutting out. But just a touch of the gas peddal and it revs right up.
The best way I can describe it is try going 10 mph while intermittenly turning the key on and off. Any other time its great.
ken98k is offline
post #2 of 11 Old 08-21-2013, 06:53 AM
Que89YJ
Is there any difference when its cold and after it warms up?
Que89YJ is offline
post #3 of 11 Old 08-21-2013, 07:01 AM
WDNewman
I had problems like this with my '89 2.5. Turns out two things were major instigators here. The timing chain was shot (154,000 miles) and the crankcase position sensor bolts had backed out and it was just barely hanging on. All the other sensors/lines were checked out and they were fine. Runs like a top now.
WDNewman is offline
post #4 of 11 Old 08-21-2013, 10:07 AM Thread Starter
ken98k
1974 CJ5
Where is the postion sensor located?
ken98k is offline
post #5 of 11 Old 08-21-2013, 12:24 PM
Que89YJ
Here is a link to download the service manual:
http://www.jeepforum.com/forum/f12/c...block-1400388/
The CPS is on the rear of the engine on the top of the bell housing. Difference hot and cold?
Que89YJ is offline
post #6 of 11 Old 08-22-2013, 10:01 PM Thread Starter
ken98k
1974 CJ5
Engine temp doesn't seem to affect on the problem. I was just thinking, this jeep has a distributer, why would it need a crank postion sensor?
Thanks for the link.
ken98k is offline
post #7 of 11 Old 08-22-2013, 11:03 PM
Que89YJ
For the injector.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #8 of 11 Old 08-23-2013, 06:34 AM
WDNewman
The CPS is located on the back of the bell housing. Drivers side at about 10 O'clock. Two bolts hold it on.
WDNewman is offline
post #9 of 11 Old 08-23-2013, 09:19 AM
Que89YJ
Use the service manual and do the check and adjustments on the ISA,TPS,WOT and the fuel pressure.
Que89YJ is offline
post #10 of 11 Old 11-02-2013, 06:53 PM
willawolfe
Just solved similar problem with my yj. Was a physically damaged spark plug. If you have not had a tune up recently. Start with the basic and cheap stuff. Plugs cap rotor, maybe wires.
willawolfe is offline
post #11 of 11 Old 11-03-2013, 08:41 PM
mlcasey13
My 95 was doing the same thing. I replaced the capacitors on the computer per some instructions I found: here http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
I know the symptoms don't agree with that thread but it fixed mine. Its worth taking the computer out and looking at the caps.
mlcasey13 is offline
