9 inch swap questions. - JeepForum.com
post #1 of 3 Old 04-04-2013, 08:22 PM Thread Starter
DontTouchIt
I picked up a big bearing 9 inch today. The seller said it had come off a Marc 2 or something. Anyways, it already has disc brakes on it. They are 5x4.5 lugs. I was wondering is it easier to swap this to 5x5.5 than trying to do discs on a bronco axle. I would prefer to keep it set up with discs.
DontTouchIt is offline
post #2 of 3 Old 04-06-2013, 02:39 PM
TSEJEEPERS
You will have a few options, it the axle flange is big enough you could have it redrilled, spacer/adapters or different shafts.
How wide is the Marc 2 axle?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 3 Old 04-07-2013, 08:11 AM Thread Starter
DontTouchIt
The axle is right around 63 inches wms, the front I'm using is 65. Figured it would be a good match.
