89' YJ won't start by itself?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 89' YJ won't start by itself??
Savvy TJ/LJ Half DoorsSavvy Aluminum Gas Tank SkidFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-13-2013, 04:11 PM   #1
Mschweit3528
Hello! I am new member here.I have owned my 89 YJ 2.5 Litre for a little over 2 years now. I'm still an amateur and learning everything about her.
But anyways I have a problem starting it. I replaced the battery, distributor coil, alternator, idle air speed motor, etc. trying to fix the cold weather problem it was having. Only problem is now I can only jump start it. Once I get it jump started, I can drive it around the block, there's no problem. Once I turn off the jeep, I can't start it back up. It's as if the battery is completely dead. Not even the gauges come on. I had the battery test, and it was fully charged. Any ideas? Let me know if you need more input from me.
Mschweit3528 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 04:33 PM   #2
broken-wrangler
Did you replace your starter?
Josh Ashley
[IMG]http://i217.photobucket.com/albums/cc65/98hondaprelude/DSC_0185.jpg[/IMG]
broken-wrangler is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 04:38 PM   #3
Mark05059
clean the grounds... battery and block. Also firewall. See if that makes any different.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 05:01 PM   #4
NonRubicon
My vote is for bad connections/grounds, or bad cables.
Try the connections and grounds first. If still no go, then try new cables.
NonRubicon is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 07:06 PM   #5
Mschweit3528
My starter I did not replace. I will go through my grounds and cables sometime this week, and let you all know. Thank you!
