89 YJ won't start has 11.88volt - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 89 YJ won't start has 11.88volt
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 10-02-2011, 10:40 AM   #1
spawnofsatan
Ok so jeep just crank won't turn over he as Accel E coil we have voltage to the coil about 11.88 is this to low? Should I go to parts store and get another coil?
spawnofsatan is offline   Reply With Quote Quick reply to this message
Unread 10-02-2011, 10:57 AM   #2
Foundrydude
Cranking is turning over. When the starter operates it's turning over the engine internals. What you probably mean is it won't fire
Start with a blast of starting fluid or pour a little gas down the carb/throttle body to rule out lack of fuel, then move on to spark.
Foundrydude is offline   Reply With Quote Quick reply to this message
Unread 10-02-2011, 11:01 AM   #3
spawnofsatan
Sorry it won't turn over we have a MC2150 Carb when I open the buffer fly give a pump I see gas squirting out so gas delivery is not a problem.
Unread 10-02-2011, 11:07 AM   #4
Foundrydude
If it won't turn over you should be looking at the starter, solenoid, battery, and cables, not the igniton. Ignition is responsible for spark, not for cranking/turning over.
Unread 10-02-2011, 11:52 AM   #5
oldtime_ironman
Does it make any kind of sound when you turn the key, like a "click" or anything?
oldtime_ironman is offline   Reply With Quote Quick reply to this message
Unread 10-02-2011, 12:50 PM   #6
spawnofsatan
Everything is cranking starter is cranking the engine ect. I have a spark tester that when you have spark the light goes on.
