89' YJ won't start by itself?? - JeepForum.com
post #1 of 5 Old 05-13-2013, 05:11 PM Thread Starter
Mschweit3528
Hello! I am new member here.I have owned my 89 YJ 2.5 Litre for a little over 2 years now. I'm still an amateur and learning everything about her.
But anyways I have a problem starting it. I replaced the battery, distributor coil, alternator, idle air speed motor, etc. trying to fix the cold weather problem it was having. Only problem is now I can only jump start it. Once I get it jump started, I can drive it around the block, there's no problem. Once I turn off the jeep, I can't start it back up. It's as if the battery is completely dead. Not even the gauges come on. I had the battery test, and it was fully charged. Any ideas? Let me know if you need more input from me.
Mschweit3528 is offline
post #2 of 5 Old 05-13-2013, 05:33 PM
broken-wrangler
Did you replace your starter?
Josh Ashley
broken-wrangler is offline
post #3 of 5 Old 05-13-2013, 05:38 PM
Mark05059
clean the grounds... battery and block. Also firewall. See if that makes any different.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 5 Old 05-13-2013, 06:01 PM
NonRubicon
My vote is for bad connections/grounds, or bad cables.
Try the connections and grounds first. If still no go, then try new cables.
NonRubicon is offline
post #5 of 5 Old 05-13-2013, 08:06 PM Thread Starter
Mschweit3528
My starter I did not replace. I will go through my grounds and cables sometime this week, and let you all know. Thank you!
