89 YJ won't start has 11.88volt - JeepForum.com
post #1 of 6 Old 10-02-2011, 09:40 AM Thread Starter
spawnofsatan
Ok so jeep just crank won't turn over he as Accel E coil we have voltage to the coil about 11.88 is this to low? Should I go to parts store and get another coil?
spawnofsatan is offline
post #2 of 6 Old 10-02-2011, 09:57 AM
Foundrydude
Cranking is turning over. When the starter operates it's turning over the engine internals. What you probably mean is it won't fire
Start with a blast of starting fluid or pour a little gas down the carb/throttle body to rule out lack of fuel, then move on to spark.
Foundrydude is offline
post #3 of 6 Old 10-02-2011, 10:01 AM Thread Starter
spawnofsatan
Sorry it won't turn over we have a MC2150 Carb when I open the buffer fly give a pump I see gas squirting out so gas delivery is not a problem.
post #4 of 6 Old 10-02-2011, 10:07 AM
Foundrydude
If it won't turn over you should be looking at the starter, solenoid, battery, and cables, not the igniton. Ignition is responsible for spark, not for cranking/turning over.
post #5 of 6 Old 10-02-2011, 10:52 AM
oldtime_ironman
Does it make any kind of sound when you turn the key, like a "click" or anything?
oldtime_ironman is offline
post #6 of 6 Old 10-02-2011, 11:50 AM Thread Starter
spawnofsatan
Everything is cranking starter is cranking the engine ect. I have a spark tester that when you have spark the light goes on.
Cold Start Turned Into No Start...Problem Resolved...Lesson Learned... tony673 YJ Wrangler Technical Forum 2 10-02-2011 07:49 PM
Can you push start / bump start a TJ? (posts from Boonie Mechanic tricks thread) Wheelin98TJ TJ Wrangler Technical Forum 162 02-08-2011 11:50 PM
Rough idle at start question....opinion before I start spending money. Cali04LJ YJ Wrangler Technical Forum 1 08-23-2010 10:07 AM
Jump start = Volt Meter spikes while driving then wont start AWILD TJ Wrangler Technical Forum 5 02-21-2010 05:37 PM
1997 2.5 will not start on incline and rough start/idle when cold. BuckeyeTJ TJ Wrangler Technical Forum 0 11-24-2009 09:39 AM
