89 YJ Wiper Woes - JeepForum.com
post #1 of 5 Old 10-24-2011, 08:35 PM Thread Starter
mgfi26
89 YJ Wiper Woes
I attribute this problem mostly to my lack of waving at other jeep drivers as they pass and happily wave. So, if anyone can help me with this issue I promise to return the wave for a period of at least two weeks. Problem - Wipers not working. Symptoms - Turn on switch and nothing. What I have done so far - Checked fuse, checked circuit breaker (assuming normally closed, good continuity good) Jumpered motor directly to battery, motor turns, When I check the incoming wires, assuming green is ground, black and white are high and low power I get -12v at both. I'm not real sure if the last part is correct regarding the high and low power but I'm definitely getting -12v instead of just 12v. This is the part that has me a little confused. Anyway, any help is appreciated and will be returned with happy jeep waves.
Thanks,
Matt
mgfi26 is offline
post #2 of 5 Old 10-24-2011, 08:50 PM
dancytron
See wiring diagram in this thread. At the motor white is low, red is high, black is ground. Green and blue have to do with parking feature.
http://www.jeepforum.com/forum/f12/y...-wires-628552/
dancytron is online now
post #3 of 5 Old 10-24-2011, 08:53 PM Thread Starter
mgfi26
Thanks for the input. I did forget to mention that I also used the ground direct to the battery and came up with -12v. That's what I don't usnderstand, why I'm getting a reading of -12v?
Thanks!
mgfi26 is offline
post #4 of 5 Old 10-24-2011, 09:11 PM
Old4X
1990 CJ7
If you have intermittent wipers, there is a module that is plugged in-line in the wiper harness under the dash. (IIRC, it is velcroed to a flat piece of metal under the dash left of steering column).
Pull the wiring down and remove the intermittent box, then just plug the harness back together without the box. See if your wipers work now. You should have OFF- LOW- HIGH and park.
These boxes give problems, though it is often just 20+ year old connectors that are gunked up, a good cleaning often makes them work again.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 5 Old 10-24-2011, 09:25 PM Thread Starter
mgfi26
I knew there was a module and was looking for it earlier. When you said velcro, that helped me find it. I removed it and plugged the two harnesses together directly and that did it. Now though, the motor runs but the wipers don't move. I'm assuming there is a stripped gear or at least improper connection mechanically. Will have to check tomorrow, too tired tonight. Thanks for the help though!!
mgfi26 is offline
wiper linkage and wiper speed? jeeptim YJ Wrangler Technical Forum 1 09-04-2011 03:05 PM
Windshield wiper / wiper motor mms1946 TJ Wrangler Technical Forum 8 11-28-2009 09:25 PM
Wiper Switch Woes Jim93YJ YJ Wrangler Technical Forum 19 04-18-2007 08:37 AM
Wiper woes K2Racing YJ Wrangler Technical Forum 10 01-05-2005 10:25 AM
Hardtop rear wiper.....is it supposed to have wiper washer too?? GregM TJ Wrangler Technical Forum 6 12-29-2002 11:48 PM
