89 YJ - Where does this hose go? - JeepForum.com
post #1 of 14 Old 06-01-2010, 10:48 AM Thread Starter
Cooper13
Greetings all,
I've got an '89 2.5 with a narrow but long hose hanging out of the rear driver's side wheel well. It is attached inside the well and the other end has what looks like a plastic nipple inserted into the end. I'm guessing it is fuel-breather-valve related but I can't find any descriptions\pictures of this line much less where it attaches. Does this sound familiar to anybody? Any suggestions?
TIA
Cooper13 is offline
post #2 of 14 Old 06-01-2010, 10:51 AM
Burnerman
Burnerman's Avatar
It could be the vacuum line to the charcoal canister. Does your windshield washer work?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 14 Old 06-01-2010, 10:54 AM Thread Starter
Cooper13
I haven't checked the washer. Didn't even cross my mind. I'll check it out tonight. Thanks
Cooper13 is offline
post #4 of 14 Old 06-01-2010, 11:29 AM
kloppk
That hose is your rear axle vent line.
It should be attached to the nipple on the axle wher the flexible brae line attaches to the "T" block on axle.
The vent hose slips onto the vertical nipple there.
kloppk is offline
post #5 of 14 Old 06-01-2010, 11:33 AM
Burnerman
Burnerman's Avatar
Ahhh..Rear drivers side...Yes! Kloppk is correct! I need to read these posts 3x from now on.....forget my pointless suggestions....
96 ZJ.
post #6 of 14 Old 06-01-2010, 11:35 AM
monkeyhouse
that's funny, I made the same mistake, lol.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #7 of 14 Old 06-01-2010, 11:40 AM Thread Starter
Cooper13
Thanks kloppk, I'll see if I can's get it squared away.
No worries Burnerman, I didn't get why the washer would be attached way back there but...
Cooper13 is offline
post #8 of 14 Old 06-02-2010, 09:37 PM Thread Starter
Cooper13
I'm not seeing an opening in my brake line connector dohickey so I took a couple pics. The first shows where it is connected behind the left rear wheel well and the plastic nipple.
Following kloppk's lead I checked out the rear axle and associated lines. Looks OK but here's a pic
TIA
I try like a sun of a gun but I'm less than proficient as a mechanic so if you have an idea, speak slowly...
Cooper13 is offline
post #9 of 14 Old 06-02-2010, 09:52 PM
monkeyhouse
I can't tell for sure, but that sort of looks like the vent hose for the transfer case.
post #10 of 14 Old 06-02-2010, 10:22 PM
Burnerman
Burnerman's Avatar
Well. There is the vent off the rear axle. It's the only rubber hose off the axle and it runs up and is supposed to be screw clamped up on the metal by the fuel filler hoses. The only other hoses are the vents for the fuel tank. There are 2 rolover vent lines off of the top of the 20 gal plastic tank. They connect to a tee fitting on the drivers side top of the fuel tank and then one line runs over the crossmember in front of the fuel tank and connects to a smal stell line that runs to the charcoal canister. I circled the valves and line in red. The tee has the arrow pointing to it. That maybe where your line is supposed to go to.
96 ZJ.
post #11 of 14 Old 06-02-2010, 10:52 PM
mike_b_ar
1987 YJ Wrangler
Okay, maybe a dumb question here, but what does a vacuum tube to the charcoal canister have to do with windshield washer? I ask because my washer doesn't work.
mike_b_ar is offline
post #12 of 14 Old 06-03-2010, 09:59 AM Thread Starter
Cooper13
Thanks Burnerman, looks like I'll be dropping my gas tank. Thank the gods for PB Blaster. Those nuts haven't come off in 21 years.
Cooper13 is offline
post #13 of 14 Old 06-03-2010, 10:33 AM
monkeyhouse
just follow it back first to make sure. No sense dropping the tank if that's not it. I figure you already did that, but thought I should mention it just in case.
post #14 of 14 Old 06-03-2010, 12:24 PM
Burnerman
Burnerman's Avatar
When I first read his post I thought he meant the drivers side FRONT of the Jeep. My mistake.The washer bottle is mounted on the rear of the front fender. If the hose broke off the pump the hose would hang and leave the plastic piece from the pump in the end. On the FI 4.0's you can remove 1 screw and slide the washer bottle up and out ( it takes some wiggling). Then you can get to the pump and the connections. If your Jeep has a rear wiper for thehardtop there will be 2 pumps.
96 ZJ.
Help!? What is the hose?! acyeehaw TJ Wrangler Technical Forum 7 01-31-2010 05:28 PM
DTC 1486: Pinched or blocked hose in the evaporative hose system. andrewnovell TJ Wrangler Technical Forum 0 10-11-2009 05:59 AM
Air Hose?? Pipedrummer TJ Wrangler Technical Forum 8 03-23-2007 12:53 PM
Hose thats under the heater core hose DirtyDog YJ Wrangler Technical Forum 4 07-23-2006 02:41 PM
oba hose.. what did you use? cueball YJ Wrangler Technical Forum 3 03-23-2006 10:55 AM
