89 YJ Speedo Gear - JeepForum.com
post #1 of 3 Old 09-07-2011, 05:15 PM Thread Starter
monkey710
89 YJ Speedo Gear
I know there are a lot of posts about this and there are excellent directions on here, but I am still having problems. I have narrowed down the problem to that the gear just isn't meshing. I am using the same gear since I bought the wrong size so that is not the problem. All the directions on here are a different transfer case and for electric speedometers so it isn't completely helpful. I am trying to line up the correct gear range, but there is no dot to line up as shown in the various directions on line. I thought I have tried every combination, but still cannot get it to seat right. Anyone have this issue and know which direction I should be trying it in? Thanks.
monkey710 is offline
post #2 of 3 Old 09-07-2011, 07:36 PM
Mark05059
dont worry about the dot part.. remove the cable then install the adapter back into the transfer. Then using an allen wrench or something similar move the gear while moving the adapter till you cant move the gear any longer. Then tighten down the adapter and reinstall the cable.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 3 Old 09-08-2011, 12:37 PM Thread Starter
monkey710
That was the perfect little tip I needed. Thanks so much!
Take a speedo gear <> Leave a speedo gear spokanistan TJ Wrangler Technical Forum 1389 02-20-2017 06:13 AM
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
Changed speedo gear-Now Speedo no worky BoatCop TJ Wrangler Technical Forum 7 08-07-2011 04:37 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
Tire/Gear/Speedo Gear question about my 97 TJ SE Black Hole TJ Wrangler Technical Forum 6 05-10-2007 09:20 PM
