'89 YJ Sahara build thread - Page 7 - JeepForum.com
post #91 of 249 Old 05-20-2009, 08:06 PM
levergun
1979 CJ5
Originally Posted by green89yj View Post
UPDATE TIME:
replaced the wheel cylinders and rear brakes.
Replaced the vacuum lines for the front axle engagement system.
Almost finished painting the dash.
Took the hard top off. Gonna whack the doors soon.
Lookin at a set of TJ sahara seats.
Now that the 4wd is fixed, I'm gonna start pricing lift and tires. Right now I'm thinking RC 4 or 6 and 33's.
TJ seats aren't bolt in. The mounting is offset and totally different. It requires purchase or fabrication of a adapter bracket. I have done it. It just takes time..... I would probably wait unless it's a real good deal.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #92 of 249 Old 05-21-2009, 08:13 PM Thread Starter
green89yj
ok. thanks man. It is a pretty good deal but not anything to get super excited about. I will probably keep looking. How complicated was it to fab up the brackets or what do they look like?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #93 of 249 Old 05-23-2009, 03:12 PM Thread Starter
green89yj
Got the 4 wheel drive working the other day and now officially drive-way tested it. Jacked up the rear end and it still rolled forward. Now I gotta go really test it. haha.
Also looking at a set of Cobra racing seats. Seem to be a good deal. Will see if they come through.
post #94 of 249 Old 05-25-2009, 10:04 AM Thread Starter
green89yj
Ok. Cobra seats got sold already. Looking at another set that popped up on craigslist.
As far as lift goes, I would love to do a 6 inch Rough Country and some 35's but is that gonna be too much for my stock axles. I still need to be able to drive it on the high way and stuff. If you remember I have the 4.2 so I won't have 4:10 4 banger gears. I guess if I grenade the 35 that is just an excuse to go to the junkyard for some 8.8's.
post #95 of 249 Old 05-25-2009, 10:06 AM Thread Starter
green89yj
So my question is
4 inch RC ----$400 or so.
6 inch RC ----$600 or so.
SOA ----------$??? or so.
What would be a good list of parts and prices for a SOA. I can't for the life of me remember where that sticky is.
Perches.
Shocks.
Brake lines.
High Steer?
CV?
If I do a CV do I have to run a SYE?
Can't I get a CV out of an XJ and cut it down?
post #96 of 249 Old 05-25-2009, 11:52 AM
chicalibro3
i'm pretty sure there's one in the FAQ section, also if you search the forum i'm sure you'll come across one
chicalibro3 is offline
post #97 of 249 Old 05-25-2009, 02:30 PM Thread Starter
green89yj
yeah. that is the only place I have left to check. My last search brought me to a few super old threads. Thanks for the tip. I will go check the FAQ.
post #98 of 249 Old 06-05-2009, 09:36 PM Thread Starter
green89yj
Well, I bit the bullet and ordered my 4" RC lift today. Ryan was out of town but I heard about a guy on TJ tech who could get me the discount. His name is Jeffery by the way.
The kit should be here on tuesday or so and I ordered extra spring bolts for it. I am currently looking for a set of 33's to mount on my 15 inch rims or a set of 17 inch rims cause my dad said I could have his 33's. I have found a few 35's, what would I have to do to make those fit? I am looking to get a little extra shackle lift and could do a slight body lift to clear them. I am just worried about running 35's on my D35.
post #99 of 249 Old 06-18-2009, 10:04 AM
Nates93yj
Nates93yj's Avatar
IMO i would get some tj flare and get 33s. But if you dont want to cut up your body i under stand, im going to cut it up before i paint it. Yeah unless you are very carfull and dont going wheekin much. But i would not do 35s not enough lift, and thats when you start finding out you weak spots. Hows it coming along
NATE
2003 GMC 2500 Duramax
2004 Jeep Wrangler Columbia Edition
1993 Jeep Wrangler
SOLD
Nates93yj is offline
post #100 of 249 Old 06-18-2009, 08:12 PM Thread Starter
green89yj
Pretty good. I am lookin all over craigslist for tires. The kit is here and I have been working on it. I'm out of town right now so I can't work on it. arghhh. My dad and I had to use a sawzall and grinder to get the rear bolts for the front springs off. Been getting really friendly with the torch. haha.
One of my dad's Ranger buddies is tryin to hook me up with some old humvee tires if the motorpool is throwing any out.
post #101 of 249 Old 06-24-2009, 10:28 AM Thread Starter
green89yj
Been working on the lift and will get pictures up soon. Cut all the rear u-bolts off with a grinder. Had to cut the rear spring bolts for the front springs off with a grinder as well. They were frozen in the sleeves. Gonna have to do the same for the rear. The shackle ends came apart just fine. Still haven't gotten the pitman arm off. Went and bought a pitman arm puller today. That is on there right now. I have been using penetrating oil and I am probably gonna go try the torch.
post #102 of 249 Old 06-24-2009, 11:13 AM
Nates93yj
Nates93yj's Avatar
Come on get some pics man..
Good luck with the pitman are
NATE
1993 Jeep Wrangler
SOLD
post #103 of 249 Old 06-24-2009, 11:34 AM
chicalibro3
that's hilarious! i'm glad i'm not the only one that wants to see the progress
post #104 of 249 Old 06-24-2009, 02:50 PM Thread Starter
green89yj
ok. got the pitman arm off with puller, breaker bar, sledge and p blaster. I am about to go get the camera and upload some pics to avoid death. be back soon. haha. none of the pics are very good cause it is being done in a garage with pretty poor lighting and not enough room for a good angle shot.
post #105 of 249 Old 06-24-2009, 03:23 PM Thread Starter
green89yj
The pictures are loading on photobucket right now. There will be a picture of the tools I used to get the pitman arm off, I'll try to get a baseline picture of how it looked before the lift, there is a picture with a measuring tape but that is not entirely accurate because the rear is on jackstands and the lift is not finished yet so don't go by that. I also don't have tires for it yet so it is sitting on like 28 or 29's or something like that. Some pictures of my break lines which are stock just re routed a little and I did not install the relocation brackets.
99 Sahara Build. Need your Help! PurpleWave TJ Wrangler Technical Forum 5 01-28-2010 02:45 PM
95 Sahara build in progress h2osprt YJ Wrangler Technical Forum 6 05-02-2009 02:29 PM
My 98 Sahara build/ long arm thread! 98blacksahara TJ Wrangler Technical Forum 11 04-07-2009 07:04 PM
90 Sahara Build jaminb YJ Wrangler Technical Forum 32 01-28-2009 05:48 PM
92 Sahara Build jsahara24 YJ Wrangler Technical Forum 9 02-02-2008 07:29 AM
