'89 YJ Sahara build thread - Page 3 - JeepForum.com
post #31 of 249 Old 03-13-2009, 07:59 PM Thread Starter
green89yj
Well I got the I6 out of the same Cherokee so I would assume that it was the -15. I just asked my dad and he agrees with me. Sorry for the confusion guys. Thanks for putting me back on track. One more question. The EFI I6 from the Cherokee would be a 4.0 instead of the 4.2 correct?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #32 of 249 Old 03-13-2009, 08:03 PM
Nates93yj
Nates93yj's Avatar
yes the renix 4.0L. correct me if im wrong
NATE
2003 GMC 2500 Duramax
2004 Jeep Wrangler Columbia Edition
1993 Jeep Wrangler
SOLD
Nates93yj is offline
post #33 of 249 Old 03-13-2009, 08:18 PM
YJSlave
Depends on the year 87-90 Renix 91-96 high out-put chrysler injection 96-00 powertech engine might still use chrysler injection
YJSlave is offline
post #34 of 249 Old 03-13-2009, 09:21 PM Thread Starter
green89yj
I believe it was out of a 94. I'll double check on that. So that would mean that it was the HO Chrysler Injection
post #35 of 249 Old 03-13-2009, 09:59 PM
Nates93yj
Nates93yj's Avatar
renix was used in the 1987-1990 cherokee.yes then its not the renix, sorry just confused with efi more used to it being called mpi multi port injection. the 1994 cherokee with have the 4.0L High Output MPI.
NATE
1993 Jeep Wrangler
SOLD
post #36 of 249 Old 03-13-2009, 10:17 PM Thread Starter
green89yj
ok. thanks guys. I just want to get it in there. haha. I can't wait till its actually able to be a dd
post #37 of 249 Old 03-17-2009, 08:15 AM Thread Starter
green89yj
I'm trying to price lift kits cause I won't have time for the engine swap for a while. What are ya'll running or which ones would you recommend. I'm plannin on jackin it up as high as possible. What are your opinions on spring over axle?
post #38 of 249 Old 03-18-2009, 08:55 AM Thread Starter
green89yj
Okay, just got a new lead on the 4.2 engine ghost. It was doing the same thing as before, ran for ten/twenty seconds or so and then crapped out. Didn't really sputter out like a fuel thing but still seemed that way. Been trying to troubleshoot the carb and fuel pump but the other night I reached over and messed with the coil and distributor and the coil was hot as a firecracker. Let it set for a while till the block had cooled off as well and went back to check it. The coil was as hot or hotter than before. Went out and bought a new coil ($16.00 at Advanced why not). Not the way I like to troubleshoot engine trouble or any other problem but I'm scratching my head as are all my other mechanically inclined friends and even my dad. What do you guys think??? As before its a 4.2 with the carter. New fuel pump and it ran perfectly three weeks ago is the part that really throws a wrench in it.
post #39 of 249 Old 03-18-2009, 06:54 PM Thread Starter
green89yj
Still nothing. I have been tinkering with it all day. Got it to the point that it idles great for about 15 or twenty seconds and then cuts out. Still can't really decide if it is a fuel thing or not because of the way it cuts out. Also when I open up the choke and look down the throat and open the throttle, it only gives me a good squirt of gas every once in a while. It was only me today so I couldn't get a good read on how the fuel pump was doing. I haven't checked the float bowl either. I'm getting really perplexed here. I could use any help you have.
Also there is a small electrical sounding pop every 8 or 9 seconds which seems to be coming from the passenger side of the block near the cab. I can't get a good fix on it and I remember it happening before the new coil as well. Bad resistor??? Bad ground???
Where would I find the resistor anyway?
post #40 of 249 Old 03-19-2009, 05:45 AM
scottsjeeprolet
Have you Nuttered it yet?
Are you running a regulator? The weber only wants 3.5 psi or your asking for trouble.
On a side note my YJ is running great!
1985 CJ-7,
1999 TJ
scottsjeeprolet is offline
post #41 of 249 Old 03-19-2009, 09:27 AM Thread Starter
green89yj
I'm happy for you that yours is running and no I haven't nuttered it yet. I'm assuming you have. That's a weber on yours right? I don't wanna upgrade to a new carb cause I am just waiting on time to swap in the 4.0. But that may take a while. Where did you splice into the wires for they nutter? What else is involved with that? Do I need to do anything special with the vacuum lines? Is it just the wires?
post #42 of 249 Old 03-19-2009, 11:36 AM
scottsjeeprolet
do a search on here for the nutter bypass. i don't have the link right now.
Have you checked your fuel pressure? Are you out of gas?
Do the bypass and let us know if it helps.
1985 CJ-7,
1999 TJ
post #43 of 249 Old 03-19-2009, 10:35 PM Thread Starter
green89yj
I have done a lot of research on the nutter bypass already and just haven't had a good chance to do it. How necessary would it be to reset the timing afterward? I don't have a timing light on me and can't exactly drive down to the parts store to pick one up. I will see what I can do this weekend.
I spent most of today cleaning it up. My friend bought a big tub of these Grime Grabber Wipe things and I just started poking around the engine trying to familiarize myself with it. I just picked a wire or a loom or hose and wiped it down and followed it to the end and checked all the connections and fittings as I went. I covered pretty much the whole thing. I cleaned up a bunch of connections and tightened some clamps. identified the wires i need to splice for the nutter now that i got the oil and crap off everything. and then after i hooked everying back up i got it started. went and drove it around. it died on me and my dad but we got it started agian. we gimped it home. had to keep it kinda wrapped up around 2000 rpm so once it was in the drive way and running i got a screw driver and played with the idle speed and the mixture screws. hopefully that fixed it.
had to take the old man out for his birthday dinner so didn't get to do another test run.
post #44 of 249 Old 03-20-2009, 05:11 AM
scottsjeeprolet
Yes you must reset the timing after doing the Nutter. Go to your local auto parts store and borrow or rent a timing light.
If you were closer i'd give you a hand.
1985 CJ-7,
1999 TJ
post #45 of 249 Old 03-20-2009, 05:35 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by green89yj View Post
Heres a pic of the engine we bought from a roll over cherokee. We also got his Aisin Warner transmission. Not sure if it's the AX5 or AX15 though. We got it in the back of the truck using the lift at the shop of the place we bought it from. But we didn't have a way to get it out of the back of the truck.
We drilled to holes in the ceiling and looped a big chain around the rafters/floor joists of the attic above and hooked a come along up to it.
sorry I can't post images yet. Still don't have the requisite number of posts.
Heres the pics of my dash so far. I should hopefully be finishing them up today. My friend is coming over and I picked up another can of Vinyl and Fabric paint last time my dad and I were out and about. I'm hoping it will be warm enough, because last time I tried it was getting a little chilly, the forecast for today is supposed to be like 70 something.
Your pics need [img] HTML tags, not [url] tags.
The 6 pics in the second quote have incomplete tag info.
At least 1 is clicky-free fer ya!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
99 Sahara Build. Need your Help! PurpleWave TJ Wrangler Technical Forum 5 01-28-2010 02:45 PM
95 Sahara build in progress h2osprt YJ Wrangler Technical Forum 6 05-02-2009 02:29 PM
My 98 Sahara build/ long arm thread! 98blacksahara TJ Wrangler Technical Forum 11 04-07-2009 07:04 PM
90 Sahara Build jaminb YJ Wrangler Technical Forum 32 01-28-2009 05:48 PM
92 Sahara Build jsahara24 YJ Wrangler Technical Forum 9 02-02-2008 07:29 AM
