'89 YJ Sahara build thread - Page 2 - JeepForum.com
post #16 of 249 Old 02-28-2009, 12:01 PM
Barrio
Its because he is useing shutterfly and codes that dont work.
Switch to Photobucket.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #17 of 249 Old 03-01-2009, 06:30 PM Thread Starter
green89yj
Couldn't get it started today. Played with the carb all day. It's the inline six with a remanufactured carter carb on it right now. My friend and I monkeyed with it all day but we didn't get anything out of it. We tore it down and cleaned it out. I think the next thing up is a fuel pump. We played with it all day and tried everything we knew. We asked my dad and he was still scratchin his head about it at dinner.
Any advice?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #18 of 249 Old 03-07-2009, 12:39 PM Thread Starter
green89yj
I'm about to go drop in a new fuel pump. Any advice?
post #19 of 249 Old 03-07-2009, 05:59 PM Thread Starter
green89yj
Well that didn't do much. I got it installed right and tried to crank it up. Ran ok for like 10 seconds then cut out. Maybe more like twenty. Let it set for a while and it did it again. Took the carb off and did a lot of adjustments. The floats were set really low and some other stuff. Put it back together and still nothing. I asked my dad and he can't think of anything else.
HELP.
post #20 of 249 Old 03-07-2009, 06:03 PM
Goobersbro
....switch it over to EFI....
My marshmallow build
Goobersbro is offline
post #21 of 249 Old 03-07-2009, 06:08 PM Thread Starter
green89yj
Thats next on the list. Hopefully over spring break. I have a fool injected I6 sitting in the corner waiting to go in in front of the AX5 thats right next to it. I just don't have time right now but still wanna be able to drive it.
post #22 of 249 Old 03-10-2009, 07:51 PM Thread Starter
green89yj
I'm hoping to be getting around to the motor install eventually and want to know what you guys think of motor mounts? What would be the advantages of going with new ones versus reusing the old ones?
post #23 of 249 Old 03-10-2009, 09:07 PM
sprngrider
You mean ax-15, right?
sprngrider is offline
post #24 of 249 Old 03-12-2009, 05:52 AM Thread Starter
green89yj
No. AX-5. From what I've read they're pretty similar. Thats what I thought when the guy said he had an AX-5. It came out of a rollover cherokee so correct me if I'm wrong but I was told that this one was an AX-5 not the -15. Maybe I just forgot a one but I googled it and the AX-5 does exist.
post #25 of 249 Old 03-12-2009, 05:56 AM
Kraxen
ax-5 is normally behind the 4 cylinder and the ax-15 is behind the 6 cylinder.
92 YJ
95 YJ
Kraxen is offline
post #26 of 249 Old 03-12-2009, 11:25 AM
zac87
Hey green89yj what mods do you plan on doing to it?
'97 TJ, 4.0L 5 speed, locker in front, Skyjacker 4in suspension, BFG AT 33x12.5, black cragar soft 8's, Bushwacker flares, Quick dicos, hardtop/doors, Safari doors, 2002 wrangler seats, tube bumpers front and rear, Skyjacker steering stabilizer, Tuffy glove box, cheap foglights, new paint ;)
SOLD: '88 YJ, 4.2L 5 speed, 31 bogs, KC fogs, herculined inside, straight piped
zac87 is offline
post #27 of 249 Old 03-12-2009, 06:51 PM Thread Starter
green89yj
Hopefully that engine and tranny swap and a lift kit. lights etc. you know. all those classics.
post #28 of 249 Old 03-12-2009, 07:00 PM
Sahara88
Sahara88's Avatar
That's a great colour you chose. Nice build
/l ,[___],
l--L-⌐°lllllll°-
Sahara88 is offline
post #29 of 249 Old 03-12-2009, 08:12 PM Thread Starter
green89yj
yeah. the color is a pretty interesting story. we went and picked it up based on a paint chip and when we got home and looked at it on a test stick we decided it was way too light, so we went back and asked them if it had a similar mix ratio to a darker green color and they said that they couldn't remix it but they gave us two small cans of black and told us to pour both cans of green into a big bucket and start mixing in black until it was dark enough for us. We poured in both of the pints and called it good enough. We started spraying around 1130 and ended at +-0300 the next day.
post #30 of 249 Old 03-13-2009, 12:36 AM
lblair04
Someone correct me if Im wrong, but Im pretty damn sure a AX-5 behind the 4.0L will tear up your tranny. Need to find a AX-15 if thats the case!
lblair04 is offline
99 Sahara Build. Need your Help! PurpleWave TJ Wrangler Technical Forum 5 01-28-2010 02:45 PM
95 Sahara build in progress h2osprt YJ Wrangler Technical Forum 6 05-02-2009 02:29 PM
My 98 Sahara build/ long arm thread! 98blacksahara TJ Wrangler Technical Forum 11 04-07-2009 07:04 PM
90 Sahara Build jaminb YJ Wrangler Technical Forum 32 01-28-2009 05:48 PM
92 Sahara Build jsahara24 YJ Wrangler Technical Forum 9 02-02-2008 07:29 AM
