89 YJ Fuel Injection Conversion - JeepForum.com
post #1 of 7 Old 10-30-2008, 06:40 PM Thread Starter
Jeepsburg
I have an 89 YJ. I think I am having a bunch of problems with my old carb (bad idle, will stall sometimes after starting or when not warm yet). So I really wanted to do a Fuel Injection swap. I had a few questions though.
1. What is a good model to use
2. Where can I get it
3. How much does it cost
4. How hard is it to put in
5. Would I have to buy any other accessories, or should it work puuurfecto
Thanks so much to any one that answers, Jon
Jeepsburg is offline
post #2 of 7 Old 10-30-2008, 07:42 PM
88TNSahara
1. Howell or Mopar
2. Quadratec, Summit Racing, or similar vendors
3. About a grand for the Howell, $2500 (?) for the Mopar
4. Quadratec claims the Howell can be fitted in 2-4 hours
5. You need a new computer, but I think they come with the kits
Go with FI if you have the cash to drop, but, if not, get a new carb. For less than $400 and about 4 hours of work, you can increase power and fuel mileage with a new carb. Weber and Motorcraft are popular choices.
88TNSahara is offline
post #3 of 7 Old 10-30-2008, 09:09 PM
timatoe
timatoe's Avatar
Depending on how handy you are, for about the price of a new carb you could do your own MPI, read this....
http://www.jeepforum.com/forum/f140/junkyard-mpi-598873/
I plan on doing the Howell myself at the end of the year.
timatoe is offline
post #4 of 7 Old 10-31-2008, 04:56 AM
yellow2kgt
I went with the Howell setup myself.
1. Yes, Starts up instantly and holds a solid idle regardless of temp and, in the 8 months I have had it not 1 single stall.
2.Direct from Howell, 4WD, Quadratec, Ebay. etc...
3. Usually they run for right under $1000 on ebay.
4. Easy, as long as you take your time. The actual install part is cake. The hard part is sorting through all of the old wires and deleting what you no longer need. I would plan on 10-15 hours to install.
5. Everything is included even the zip ties. However, Depending on what air cleaner you are running you may need to buy a new one. The factory one will not fit but you can pick up a generic filter from autozone for ~ $20.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #5 of 7 Old 06-09-2009, 12:04 PM
Peanuts89yj
I just bought a 89yj w/ 4.2 block w/ 4.0 heads injected. 4wd does not work. Is this still a vacuum driven system now? Would I troubleshoot it as a 4.0 set up? help!!!!!!! please!!!!!!!
Peanuts89yj is offline
post #6 of 7 Old 06-09-2009, 11:05 PM
timatoe
timatoe's Avatar
This really has nothing to due with the fuel injection. All YJ's use the same vacuum actuated front axle in stock form.
Read this thread... http://www.jeepforum.com/forum/f12/home-made-posi-lock-write-up-595515/ You'll never have to worry about it again.
timatoe is offline
post #7 of 7 Old 06-09-2009, 11:14 PM
antec
i got the howell tbi and love it hold thing from beging to end cost 1300. i will have some video of it runing soon but trust me you will love it
antec is offline
fuel injection conversion Nutter78 YJ Wrangler Technical Forum 5 05-09-2009 08:38 PM
Fuel Injection conversion? Ron Smith YJ Wrangler Technical Forum 5 05-21-2008 09:42 AM
Fuel Injection conversion kit??? clint_ives YJ Wrangler Technical Forum 6 09-08-2007 03:00 PM
258 Fuel Injection Conversion BeatAChevy289 YJ Wrangler Technical Forum 3 06-07-2004 05:03 PM
'88 YJ Fuel Injection Conversion YJHoller YJ Wrangler Technical Forum 10 11-08-2002 07:49 AM
