89 YJ Electrical Issues blinkers/ dash lights come on with Brake lights - JeepForum.com
post #1 of 10 Old 02-15-2008, 06:00 PM Thread Starter
Cajun90YJ
89 YJ When I push the Brake Pedal all my dash lights come on along with the front blinkers, and radio. It looks like the clutch master cyl may have leaked fluid on the wiring block on the fire wall. I Was wondering if any one has run into these issues before? Just looking for somewhere to start looking.
Cajun90YJ is offline
post #2 of 10 Old 02-15-2008, 07:51 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
If it started after the brake fluid leaked for a while maybe some electrical contact cleaner in a aerosol can could be the answer to your problems.
laybackman is offline
post #3 of 10 Old 02-15-2008, 08:21 PM
pat8942
pat8942's Avatar
Yeah thats probably the problem but, you better clean it quick and fix that master because brake fluid is corrosive and it will wreak havoc on those electric connections.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #4 of 10 Old 02-16-2008, 05:15 PM Thread Starter
Cajun90YJ
Well my hunch was wrong the block was fine no issues there, it still had the grease on it. So im thinking there must be something shorted under the dash or something crossed somewhere but I dont know where to start.
post #5 of 10 Old 02-16-2008, 05:34 PM
kingcn
Troubleshooting
I had a similar problem with my Mazda pickup, only when I would use my turn signal most the lights in my dash would blink. I thought it was the multi-switch so I bought a new one only to find it didnít fix the problem. At this point I started studying the wiring diagrams looking for something common to all the lights that would blink and the turn signal. After checking many components I ended up back by the brake lights and it turned out to be a wet corroded trailer light hookup. When I unhooked it everything worked great. So to make a long story longer get out the schematics and start looking for and checking points that are common to all the lights that are coming on.
_____________________________________________
Front: Dana 30 4.10: Yukon Chrome-molly axles / Super Joints & Lock-Rite locker
Rear: Dana 35 4.10: Yukon Chrome-molly axles & Lock-Rite locker
C & C Fab Tube Fenders (giving these guys a plug because they treated me so well)
Home brew oil-pan/bell housing skid plate and gas tank skid plate.
kingcn is offline
post #6 of 10 Old 02-16-2008, 05:46 PM Thread Starter
Cajun90YJ
Yea sounds like a good starting point. Thanks
post #7 of 10 Old 02-16-2008, 06:50 PM
ctm
there is only one wire that comes out of the brake switch and into the steering column connector. There are two (one for each brake light) that exit the steering column over to the body harness. Follow any of these three and look for a short to the power distribution wires for your dash that go through the dash dimmer.
I only have colors for 90, yours may/may not be the same:
dash power distribution: orange/black
exiting brake switch to steering column: light blue/black
from steering column to body harness: brown, green/black
ctm is offline
post #8 of 10 Old 02-16-2008, 07:11 PM Thread Starter
Cajun90YJ
Ok I will check that in the morning sounds like it could be possible the only other thing would be the front turn signals? They come on solid like the brake lights so I was thinking it may be in the fuse block. Something shorted in the block.
post #9 of 10 Old 02-19-2008, 04:51 PM Thread Starter
Cajun90YJ
Well I have figured out that my problem is a ground. It is in the left blinker/brake I'm thinking in the switch assy or the wiring in the column. I'm still working on it though.
post #10 of 10 Old 10-03-2010, 05:33 PM
dancytron
For future reference, I pm'd cajun90yj and he said it turned out to be a short in the left tail light. Mine was doing the same thing and it turned out to be the exact same cause.
dancytron is offline
1987 Wrangler Electrical Issues - no headlights, taillights, brakelights, dash lights rconn14 YJ Wrangler Technical Forum 13 05-26-2012 05:51 AM
93 YJ electrical issues- no brake or tail lights sethp17 YJ Wrangler Technical Forum 3 02-19-2009 05:26 AM
TJ blinkers and brake lights donít work. jeepdummy TJ Wrangler Technical Forum 3 11-14-2008 02:06 PM
no blinkers, hazards or brake lights 04Willys TJ Wrangler Technical Forum 10 04-10-2007 07:10 PM
Electrical Problem - lights and blinkers CuzzinOlaf YJ Wrangler Technical Forum 9 08-13-2003 08:17 AM
