89 YJ Axle Rebuild - JeepForum.com
post #1 of 7 Old 05-01-2013, 01:50 PM Thread Starter
zombiecommander
89 YJ Axle Rebuild
I am doing a rear axle rebuild. I'm going to go with G2 Axle & Gear. The smallest gear ratio they make is 3.73, but my front is 3.07. Will this be a problem until I make some money and buy 3.73 for the front?
zombiecommander is offline
post #2 of 7 Old 05-01-2013, 04:56 PM
PA_YJ19
As long as u only drive in 2wd u will b fine. Put in 4wd and things r going to break...
PA_YJ19 is offline
post #3 of 7 Old 05-01-2013, 05:01 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
To give you quality feedback (especially since you have not filled in your profile telling us what equipment your Jeep has, year, engine, tranny etc) we need to know what rear axle you have right now that you wish to rebuild.
If its a stock D35 or D35C - I wouldn't invest in rebuilding that axle knowing its reputation all too well.
Also, if it is a stock D35 or D35C, seems you got some bogus info as far as a ratio change since it can easily be regeared to 4.88 if you change the carrier at the same time.
You can run two different ratios in the differentials - precautions and a few steps need to be taken to ensure you don't use 4wd.
Joe Dillard is offline
post #4 of 7 Old 05-01-2013, 05:10 PM Thread Starter
zombiecommander
I'm keeping it a D35 because it is my DD. 3.73 is the highest I'm going to go for now because of fuel economy.
post #5 of 7 Old 05-01-2013, 05:11 PM Thread Starter
zombiecommander
Thanks man. That's what I thought, just making sure. Thanks
post #6 of 7 Old 05-01-2013, 05:30 PM
Mark05059
Fill out your jeep profile.. There is alot to getting the right gears (including fuel economy)
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 7 Old 05-01-2013, 05:35 PM
zeus87gn
1987 YJ Wrangler
An 89 will bave the heavy D35 without the c-clips
You shouldnt have any problems out of it...unless ypu swap in a bigger motor
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
