'89 Wrangler 2.5L - High idle after warm - Help? - JeepForum.com
post #1 of 5 Old 04-02-2005, 03:19 PM Thread Starter
Rich in Almaden
Thanks in advance to anyone with advice. My brother has an '89 2.5L with about 150k miles. When starting cold, engine runs rough at around 700 rpm, but as it warms up, it smooths out, but is running 1500 rpm.
He's also seen an increase in fuel consumption from ~20 mpg to 15 mpg. The plugs are new and properly gapped, but he still needs to replace the distributer cap and ignition wires.
Anyone have anything else he should be checking? He lives in Hawaii and parts are very expensive - so just swapping out parts is not a cheap thing to do. Also, the dealer won't work on his vehicle any more as they say it's too old.
Thanks for your help.
Rich
Rich in Almaden is offline
post #2 of 5 Old 04-02-2005, 07:19 PM
ast90YJ
I got the same problem...It should be going into the shop soon to get fixed cayse u can.t figure it out. Im pretty sure it has to do with the computer but we'll see wha the mechanic says
ast90YJ is offline
post #3 of 5 Old 04-03-2005, 05:45 AM
Jeepsohigh
I have an 89 2.5 and was having the same problem. it turned out to be the coolent sensor. it is a sensor that goes in the intake that tells the computer how rich/lean to run depending on the temp.
hope that helps
89 YJ-7" lift-35" tires-4 popper and lots more
and
Jeepsohigh is offline
post #4 of 5 Old 04-03-2005, 01:38 PM Thread Starter
Rich in Almaden
Thanks Jeepsohigh - do you recall if it was called the MAT sensor (Manifold Air Temp)?
Thanks again for your thoughts.
Rich
post #5 of 5 Old 04-04-2005, 02:10 PM Thread Starter
Rich in Almaden
From what I've found the MAT sensor should read less than 1000 ohms when the engine is warm. It seems like I'm getting the correct reading ~700 ohms.
Any other ideas?
Thanks,
Rich
Low Idle Cold, High Idle Warm Lon33 YJ Wrangler Technical Forum 13 10-29-2014 09:24 PM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
problem at warm-up/idle xj 98/yj 94 YJ Wrangler Technical Forum 9 03-07-2007 04:23 PM
Idling high after warm SonofSam02 YJ Wrangler Technical Forum 1 02-10-2007 10:23 PM
high idle in warm weather wardstar YJ Wrangler Technical Forum 3 06-24-2004 01:54 AM
