89 wrangler 15 to 20gal tank swap - JeepForum.com
post #1 of 30 Old 11-22-2011, 05:26 PM Thread Starter
doops22
I have a 89 wrangler. the original steel 15 gallon tank was rusted and starting to leak. I got a 20 gallon plastic tank from another parts jeep with the skid plate. I saw a few threads and saw some pics about this and that it should work. Just have a few questions. The original tank has been out for a while waiting for a replacement. I see a line coming from inside the passenger side fenderwell, but I don't see a hose on the new 20gal tank that would go there, I'm assuming it's just another vent from the 15gal tank? The 20 gal just has a vent on either side of the sending unit. I got the tank up close to being in place but need to lengthen the 2 lines to the sending unit, and looks like I'll need to shorten the fillerneck hose. There's a small spot on the 20 gal tank that looks like it is melted from sitting on the exhaust in the jeep it came out of, my exhaust is pretty close in the same spot so I'll probably end up fabbing up some sort of heat shield and try to tweak the exhaust as far from it as I can. Appreciate any help guys, just trying to get this thing going. This should be the last thing I need to get it going.
doops22 is offline
post #2 of 30 Old 11-22-2011, 05:38 PM
brentd711
I've got a steel tank, if you're interested PM me
brentd711 is offline
post #3 of 30 Old 11-22-2011, 11:36 PM Thread Starter
doops22
I've got a friend with a steel tank that I can have. would like to use this one though. 5 extra gallons and I'm sure you know how easily stuff rusts up here. id rather just have the plastic tank and not worry about it. thanks though
doops22 is offline
post #4 of 30 Old 11-23-2011, 04:17 AM
timatoe
timatoe's Avatar
Just giving you a bump for the night, don't have time right now at work. I did this swap will try and provide more info tomorrow.
timatoe is offline
post #5 of 30 Old 11-23-2011, 03:54 PM
timatoe
timatoe's Avatar
OK so the line on the passenger side if from the roll over valve. That line will connect to the two vented lines from the tank, the two sides connect together toward the middle with a "T" then run over there. The fuel feed line and the vent going to the evap canister come off of the main ports at the sender. I can't say on the fuel filler and vent from the filler neck because I moved the filler neck to the TJ location and used the TJ filler so I had to make my own lines for that. You can likely get the correct size filler and vent hoses from MTS.
timatoe is offline
post #6 of 30 Old 11-23-2011, 05:51 PM
mrmud4x4
I just pulled my tank out of my 88. I was suprised to find the 20 gallon plastic one. I needed to adjust the float resistor and seal the top gasket. I also needed to clean/paint the skid plate and replace the vent hose that is assembled with the filler hose. That big vent hose was probably the source of my leak.....it was dry rotted bad at the tank end clamp. I will probably re-mount the tank friday.
The vent lines on top were tied together and went up to a vent on the drivers side on my jeep. There was also the fuel feed and return lines in the same spot on the drivers side.
I also have a fitted rubber mat, maybe 1/8 inch thick, that lays in between the skid and the plastic tank.
The whole skid/rubber/outside bottom of tank was full of dirt and crud, with a little rust inside the skid plate.
The exhaust pipe on mine probably sits about 4-5 inches from the plastic tank, and there is not any noticable damage to the tank.
The reason I did not know what size it was is because when I bought the jeep, I filled it up and it leaked ...... I never filled it again.... now that problem should be fixed along with the tank level reading.(would only go to 1/4 tank - I never knew how low it was)
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #7 of 30 Old 11-24-2011, 06:40 AM Thread Starter
doops22
thanks! do I need to hook up the roll over valve? or can I just run the vent lines somewhere they won't get full of crud. not exactly sure what its for? my samurai just has the vent at the filler, not sure why this tank has so many. also I didn't notice an evap canistrr. I followed the line from the mech pump on the passenger side of the motor along the driver side frame rail to the tank to determine which line needed to be the feed.
doops22 is offline
post #8 of 30 Old 11-24-2011, 06:48 AM Thread Starter
doops22
thanks. theres a vent line tied up with my feed/return on the driverside also. this was where I was planning on routing it if I don't need this roll over valve. the fuel gauge didn't work before. maybe it will with the sending unit in this tank. if not ill just use the tripometer.
doops22 is offline
post #9 of 30 Old 11-24-2011, 07:38 AM
mrmud4x4
I did not find a rollover vent line when I pulled mine. The 2 vents on top were tied together and went to the drivers side.....there are three lines there. feed, return and vent....vent being the small one. return should come off the fuel filter up on top of the engine.
mrmud4x4 is offline
post #10 of 30 Old 11-24-2011, 07:43 AM
mrmud4x4
If you can get a multimeter...the float is very easy to check. Read resistance accross the two plug pins; full tank = about 100 ohms, empty tank = 2-3 ohms. (that's how mine was) I pulled my float out and the resistor cover off. I used a small needle nose and jewelers screwdriver to make sure the resistor tab was riding on the resistance winding throughout the motion of the float. very simple device.....
mrmud4x4 is offline
post #11 of 30 Old 11-24-2011, 08:43 AM
pasinbuy
Before you install your new plastic tank. Check to see if there is a 6 inch tube in the vent. If the 6 in tube is there cut it to about 1.5 inches to make your plastic tank a true 20 gallon tank.
Other wise it will be a 15 gallon tank.
pasinbuy is offline
post #12 of 30 Old 11-24-2011, 09:31 AM
mrmud4x4
are you talking about a tube inside the tank?
mrmud4x4 is offline
post #13 of 30 Old 11-24-2011, 02:00 PM
timatoe
timatoe's Avatar
You should run the rollover valve, if you don't that's up to you. The only vent on the driver side should be the rear diff vent.
timatoe is offline
post #14 of 30 Old 11-24-2011, 02:28 PM
mrmud4x4
I do not know if I have a stock tank or not....but from the looks of the caps that the vent lines tie into on the tank....they look like if the tank was upside down, they would not leak....I can test that theory tomorrow. Still have the tank out....can take pics of it also.
I do have the vent line from the rear diff.....goes up to a vacuum cap behind the gas cap/filler tubes in the rear driver side quarterpanel.
As far as the vent line to the tank, it is run next to the fuel lines on the drivers side and it does look stock....it has been there clamped together with those fuel lines for what looks like the life of the jeep. I can trace that vent line out to see where it goes also.
Am I thinking correctly...is it a vent line? I don't have FI? It ties to what I am assuming are the two vent caps on top of the tank. There are no clamps on the vent lines...they just push on the fittings.
There were no other vent lines coming from that tank. I just pulled the tank out on monday.
My jeep is the 1988 Laredo YJ
mrmud4x4 is offline
post #15 of 30 Old 11-24-2011, 07:06 PM
timatoe
timatoe's Avatar
Hmmm, a picture would be helpful, that definitely doesn't sound right.
timatoe is offline
15 to 20gal mod? jonny93yj YJ Wrangler Technical Forum 15 06-18-2011 05:54 PM
Wrangler YJ With 88 XJ Fuel Tank DVSYN YJ Wrangler Technical Forum 2 01-07-2011 07:39 AM
91 Wrangler Fuel Tank ssebastian YJ Wrangler Technical Forum 4 09-21-2008 11:31 AM
87 4.2l wrangler gas tank depth lidlitalian YJ Wrangler Technical Forum 1 08-09-2008 09:56 AM
91 Wrangler gas tank mmmhj YJ Wrangler Technical Forum 4 01-04-2007 08:10 AM
