'89 Timing Issue - JeepForum.com
post #1 of 3 Old 02-18-2013, 04:41 PM Thread Starter
jbrown73
'89 Timing Issue
Recently completed Nutter Bypass & Weber 32/36 install on an '89 Wrangler YJ I recently purchased. Went to set up the timing and noticed the timing mark to be TDC and not even on the degree scale. Adjusted the distributor as far as I could without damaging the engine and still could not get the timing mark on the scale. Suspect the previous owner removed the distributor and somehow rotated the crankshaft before reinstalling the distributor. Here's my question.....
If I set the #1 piston to TDC using a compression gauge, how do I install the distributor so it is aligned properly? I attempted to set it by ear, but kept getting backfire through the carb and read on several post where the timing is 9 times out of 10 the culprit.
Thanks in advance!
jbrown73 is offline
post #2 of 3 Old 02-18-2013, 04:44 PM Thread Starter
jbrown73
Guess I should have included the engine size (258 I6)....sorry for the additional post.
jbrown73 is offline
post #3 of 3 Old 02-18-2013, 05:42 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Check the timing chain for slack.
http://s702.photobucket.com/albums/w...=VIDEO0008.mp4
http://s702.photobucket.com/albums/w...=VIDEO0009.mp4
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
