'89 starter: hex/external "torx" size - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > '89 starter: hex/external "torx" size
TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-20-2015, 09:26 AM   #1
fishadventure
I am 700 miles from home (Vermont) and my "normal" tools. In Arlington, Virginia.
If I remember correctly the starter bolts were 12-point heads when I replaced it about a year ago. The drive has apparently failed so the shortest route is to just buy another one if I can't find a starter shop nearby. Either way. I need to take it out.
I need to buy the 12-point socket: what size is this socket?
My cheap Stanley travel kit only has 6-point in it. Always meant to pick up the right size to add to my travel tools or change out the bolts but of course I haven't..... Thanks.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 02:50 PM   #2
fishadventure
Oh and it's a 89 with 2.5 - maybe I'll have to drive to harbor freight and buy some cheapo set?
There's a car quest in sterling, va along with a hf.
Unread 03-20-2015, 02:59 PM   #3
Jeepsr4me
Its not 12 point... Its a torx external... and its a 10 or 8 I can not remember.. Just get the cheap set they sell at HF...
I got a set from AZ that had all of them and a few safety torx sockets.
here is a example....
Jeepsr4me is online now   Reply With Quote Quick reply to this message
Unread 03-20-2015, 03:10 PM   #4
imstillatwork
I think it's an e12.
imstillatwork is online now   Reply With Quote Quick reply to this message
Unread 03-20-2015, 03:10 PM   #5
imstillatwork
haha, just like the engraving on the socket in the pic.
Unread 03-20-2015, 03:12 PM   #6
fishadventure
Originally Posted by Jeepsr4me
Its not 12 point... Its a torx external... and its a 10 or 8 I can not remember.. Just get the cheap set they sell at HF... I got a set from AZ that had all of them and a few safety torx sockets. here is a example....
thank you. I remember now. So this will be my third set of hf external torx now that I think of it..I did buy a set for the road kit last winter but it's at home with the other set. >sigh<
Unread 03-20-2015, 07:37 PM   #7
fishadventure
Almost did it in the parking lot at HF (which was in the same strip mall as carQuest) but it was wet and dark and 35ish.
So I will do it tomorrow as it is supposed to be 60 and sunny and dry. Shouldn't take 10 mins.
Unread 03-21-2015, 10:17 AM   #8
Anticanman
Follow me
Anticanman's Avatar
Just remember to replace the bolt with something that you carry tools for.
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 08:26 PM   #9
fishadventure
All done... And I have the brandie new HF etorx sockets in the "suitcase" toolkit
Did it on the top floor of a parking garage in the sun. No probs
