89 Jeep Sahara losses Rpms while driving - JeepForum.com
post #1 of 11 Old 06-26-2012, 07:31 PM Thread Starter
WnxMike
Hey everyone, Im having trouble with my 1989 Jeep Wrangler. The issue is this Ill be driving down the road and ill loss power ( I can press the gas but Rpms wont go up) the Jeep does not die, but i cant accelerate. I usually pull over turn it off wait 1 min turn it back on and im good to go for a little bit. I've replaced the fuel filter. I thought it was not receiving gas and thats why it was cutting out, but my fuel pump is fine i believe. I still think it maybe fuel related, but what do you guys think? one of my friends said the filter by my gas tank needs replaced, but im not sure what that part is to order it.
I was also reading up and maybe it can be an electrical thing, if you guys can give me some specifics I'd be very happy
other specs: 4.2 liter 6 cylinder 5 speed manual
WnxMike is offline
post #2 of 11 Old 06-26-2012, 09:08 PM
WVYJ
sounds like the vacume advance in the distributor I replaced mine with 4wd's hei for just over $100
WVYJ is offline
post #3 of 11 Old 06-26-2012, 09:47 PM
evanjeep
2011 WK
Mine does this too. No clue what the heck is going on
evanjeep is offline
post #4 of 11 Old 06-26-2012, 09:48 PM
evanjeep
2011 WK
Mine runs off the manifold whats it doing when it shuts off
evanjeep is offline
post #5 of 11 Old 06-26-2012, 11:51 PM
shagsjeep
Try replacing that vacume line. Maybe it's collapsing when u step in it???
1989 Jeep wrangler YJ. 4.2L 258 in-line6, front dana 30 rear dana 35?? NP231 nothing fancy yet.
shagsjeep is offline
post #6 of 11 Old 06-27-2012, 12:58 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Vacuum is high at idle and low when you step on it. So it wouldn't be collapsing while accelerating.
When was your last tune up?
Any fuel economy changes lately?
Have you tested the fuel pressure yet?
ratmonkey is offline
post #7 of 11 Old 06-27-2012, 04:11 AM
Mark05059
Im guessing your still carb'd?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 11 Old 06-27-2012, 09:36 PM Thread Starter
WnxMike
I do hear vacume loss/ noise when i slow down some times. also, yes im still carbed and i where would i check the fuel pressure at?
WnxMike is offline
post #9 of 11 Old 06-28-2012, 01:21 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Unless I am blind, there isn't a fuel filter by your tank unless a PO added one. The only one I could find on my Jeep is in the engine bay right before the carb. Cost about 8 bucks at Napa. Easy, cheap insurance.
Michaelgoesrawr is offline
post #10 of 11 Old 07-02-2012, 10:32 PM
evanjeep
2011 WK
Mine only seems to do this a 2k rpms and 35mph in 3rd gear
evanjeep is offline
post #11 of 11 Old 07-08-2012, 10:20 AM
WVYJ
start it up pull the vacume line off the carb that goes to the distributor and suck on it if rpm's should increase if they don't it's the vacume advance in the distributor and yes it will leave a bad taste in your mouth
WVYJ is offline
Loosing RPMs while driving... any ideas? surfsefl YJ Wrangler Technical Forum 5 06-20-2016 01:16 PM
89 Sahara losses Rpms WnxMike YJ Wrangler Technical Forum 0 10-07-2011 11:28 AM
Cut my losses and go full width? Apollo12227 YJ Wrangler Technical Forum 13 03-23-2011 06:36 PM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 10:22 PM
94 jeep losses power around 3,000rpm cody11ca YJ Wrangler Technical Forum 5 09-04-2007 07:00 PM
