89 jeep runs crapy under 1,000 rpms! - JeepForum.com
post #1 of 5 Old 08-18-2011, 11:17 AM Thread Starter
dougbrown
My 89 yj wrangler with a 4.2 I6 and webber 32/34 carb run crapy under 1,000 rpms. It doesn't idle steady and never has. Wants to idle any where from 900 rpms down to 500 on somedays. It seams over the last few days it just wants to stall when your starting out in first gear. It drops way down and then pops and sputter. If I push the clucth in it will come back up to 700 or 800. If I reve it up and then let the clutch out she fine. It also does it down shifting too at time. Once your going it seems to run just fine. It has a little owder to the exhaust but no smoke. I had replaced and caped all the vacuum lines. Also rebuild the carb a few months ago when I bought the jeep. I don't want to take it to a shop just yet so any info would be great.
I want to do the nuter by pass but not sure if I'm keeping that engine in it.
Thanks Doug!
dougbrown is offline
post #2 of 5 Old 08-18-2011, 11:34 AM
dancytron
You should do the Nutter. The computer is trying to control the stock carb but can't because it isn't there anymore. It is controlling the timing but is confused. More than likely many of the sensors the computer relies on have failed by now. After you do the Nutter you can tune it without the computer interfering.
dancytron is offline
post #3 of 5 Old 08-18-2011, 11:46 AM
swatgig17
1987 YJ Wrangler
Thanks Doug!
You probably spent more time capping vac lines than you would doing the nutter. I don't remember spending much time on it.
swatgig17 is offline
post #4 of 5 Old 08-18-2011, 03:47 PM Thread Starter
dougbrown
The nutter by pass is all ele right?
post #5 of 5 Old 08-18-2011, 04:01 PM
dancytron
Since you already have a different carb, it is just the two wires bypassing the computer and retiming it. Then you can tune the carb so it runs right (unless something else is wrong with it).
http://www.jeepforum.com/forum/f8/ho...bypass-522262/
1995 Jeep Wrangler 2.5L 4cyl 129k cel 12, 33, 55 - Runs sluggish at idle/low rpms? SomerJeep YJ Wrangler Technical Forum 8 11-14-2010 07:06 PM
Jeep sputtering at low RPMs Sparkfly88 YJ Wrangler Technical Forum 7 10-27-2010 09:15 PM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 10:22 PM
4cylinder Hard to Start / Stalls / only runs smooth in mid RPMs carcollector TJ Wrangler Technical Forum 0 01-05-2010 11:35 PM
911 -- Help Jeep dying at 2500 RPMs!!! corst01 YJ Wrangler Technical Forum 23 03-19-2005 09:59 AM
