89 cj wrangler nutter trouble - JeepForum.com
post #1 of 2 Old 11-19-2015, 11:47 AM Thread Starter
roempty
Hi everyone thanks in advance. My son just got jeep was running pretty good and he did nutter got no start. I looked at wiring he had it wired wrong at start modular. He connected to wires going into harness. I changed wires to orange and purple going into start mod still no start. So I put back to original way it was wired and still no start. Do you think something could have gotten messed up when he had it wired incorrectly and tried to start. ANY HELP WOULD BE GREAT. Thanks again in advance
roempty is offline
post #2 of 2 Old 11-19-2015, 12:35 PM
Mike Romain
If he messed inside the harness, he might have gotten/cut the wrong orange wire. I would open the harness up to be sure.
When doing the nutter, I always recommend two new twisted together wires to hook the distributor directly to the ICM on the drivers inner fender. Have you read this link? http://www.jeepforum.com/forum/f8/ho...bypass-522262/
Might help you figure it out.
That said,when I did the nutter, I had no start too. After double and triple checking everything, including a tow home, I figured out the pickup in the distributor wasn't strong enough to fire the ICM but it would trigger the ECU. The test is 400-800 ohms between the orange and purple going into the distributor with 650 the best. Mine was at 485.
Also be aware the hold down foot for the distributor is the ignition ground. Loosen it to adjust the timing and if it is rusty you can lose spark. The black wire going into the distributor can get a dedicated ground wire to it to get around that.
Good luck.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline
