89 ccv and pcv valves - Page 2 - JeepForum.com
post #16 of 18 Old 08-12-2011, 03:26 PM
laredojo
Advanced auto parts sold me a replacement oil cap with a rubber gasket just last year. As far as the gromets go you are going to need to try ad crossmatch something. Or go to the JY and look at different engines, see who uses what.
If you used the 94 air box then you are probably missing the inlet tube for the breather hose. It should be on the back of the intake box lower inside corner, about 3/8ths or so in diameter. This hose pulls air through the breather form the crankcase into the intake of the engine. I dont know if the 94 had this nipple on the airbox or not.
formerly member yj89joe
laredojo is offline
post #17 of 18 Old 08-12-2011, 03:32 PM
oldtime_ironman
Pretty sure they have all the stuff in the "HELP" section at autozone and etc. At least most of the stores around here do.
oldtime_ironman is offline
post #18 of 18 Old 08-12-2011, 03:43 PM
icenikka
Anyone know the dimensions of the pcv valve hose for an 89 wrangler 4.2L?
I.e.
Inner diameter, hose thickness, hose length?
Mine is so beat up that I'm afraid of taking it out without being able to toss in a replacement right away.
icenikka is offline
