89 ccv and pcv valves - JeepForum.com
post #1 of 18 Old 08-11-2011, 06:06 AM Thread Starter
Fuddmaster
Ok I give up I thought I could figure this out. My valve cover on my 2.5l leaks oil around the oil cap and from the grommets on top. I have a pcv in both holes with grommets. I know it's not right but none of the local parts store or dealership are helpful. What have you guys done with it?
Fuddmaster is offline
post #2 of 18 Old 08-11-2011, 08:06 AM
oldtime_ironman
The ccv system doesn't use any PCV valves. Best bet is to just use straight vacuum hoses and make sure everything breathes freely. The smaller hose at the front of the valve cover can be problematic - I check once a year and clean everything out with solvent. Especially make sure that the fittings in the valve cover aren't clogged.
oldtime_ironman is offline
post #3 of 18 Old 08-11-2011, 12:08 PM Thread Starter
Fuddmaster
For some reason I had it set up that way. Do you have a pic of how you have it set up?
post #4 of 18 Old 08-11-2011, 12:53 PM
oldtime_ironman
Nope I don't have a pic handy, but its bone-stock. Factory hoses and all, I just make sure to clean everything out real thoroughly especially the orifices in the valve cover. I also make sure there's no leaks, especially on the little connecting hoses on the small line. Those hoses get stiff with age and heat and then they don't hold vacuum so well - that's when it starts to spit oil.
post #5 of 18 Old 08-11-2011, 04:30 PM Thread Starter
Fuddmaster
Mine wasn't bone stock when I got it. And i can find the ccv grommet but not the ccv valve. Ill have to keep fiddleing till I get it thanks
post #6 of 18 Old 08-11-2011, 05:18 PM
oldtime_ironman
For sure you need to lose the PCV valves tho. I would figure out a way to just run plain old hoses. There's probably adapters so you could put hoses in the grommets, check at someplace like autozone.
post #7 of 18 Old 08-11-2011, 06:06 PM Thread Starter
Fuddmaster
Don't run any at all or just not in the back?
post #8 of 18 Old 08-11-2011, 06:19 PM
oldtime_ironman
Don't run any at all. Just straight hose on both the front and back. That's basically what the stock jeep setup does anyway.
post #9 of 18 Old 08-11-2011, 06:28 PM
laredojo
Here is a picture of mine, also an 89 2.5. The front one is a pcv valve, I took it out and shook it, it rattles. The rear one is a breather. Both connect to the steel bundle of vacume lines that plug into the base of the carb, there are 4 ports on the valve cover side at the bottom. The pcv valve connects to a steel line that goes towards the front of the engine the rear breather connects to a larger of the bundle and a rubber line connects to the other end of the steel line and plugs into the air box.
hope this helps.
formerly member yj89joe
laredojo is offline
post #10 of 18 Old 08-11-2011, 06:35 PM
Xpress
My oil filler cap and the PCV both leak. I have checked ALL over and nobody stocks the rubber gasket for the PCV valve that goes onto the cover. Anybody know where to get one? also my oil fill cap is clean as a whistle, and so is the mating surface on the valve cover, but oil leaks out. Anybody make a cork gasket for that??
All about that unibody life.
Xpress is offline
post #11 of 18 Old 08-11-2011, 06:47 PM
laredojo
The leakage is caused most likely by blow by. Make sure all the steel tubing is clear and free of crud, the vacum ports are clear. and the airbox is tight. clean out the pcv valve and the beather, the more suction you can get to these 2 the better. Mine isnt dry but its 200% better now than when I got it.
As far as the gromets go, look at the Help rack at auto zone,some gromet will be the right one you just need to figue out which one.
also for the oil filler cap I added another rubber gasket I made from a bicycle inner tube. That tightened things up nicely.
laredojo is offline
post #12 of 18 Old 08-11-2011, 06:55 PM
oldtime_ironman
His is a 1994 which is similar to my 1991. There isn't any breather or PCV valve on it. I'll have to post up a pic tomorrow when I have some daylight. Whoops just noticed that the engine was swapped.. dunno which valve cover or ccv system was used in the swap tho...
post #13 of 18 Old 08-12-2011, 12:50 PM Thread Starter
Fuddmaster
89 valve cover was used with 94 intake system. I wasn't sure if I could use the 94 cable cover on that motor so I didn't swap that over. Theres another question does anybody know if I can switch them. I know there different but do the holes line up?
post #14 of 18 Old 08-12-2011, 12:56 PM Thread Starter
Fuddmaster
89 valve cover was used with 94 intake system. I wasn't sure if I could use the 94 valve cover on that motor so I didn't swap that over. Theres another question does anybody know if I can switch them. I know there different but do the holes line up?
post #15 of 18 Old 08-12-2011, 01:02 PM
oldtime_ironman
You probably should go with the 89 style PCV then. I don't know about the cable cover but I see no reason why they should be very different - after all, the block and head is the same. Worse comes to worst you could always modify the cable cover to fit.
