89 4cyl YJ no spark - JeepForum.com
post #1 of 13 Old 08-24-2011, 04:59 PM Thread Starter
midnight_f150
89 4cyl YJ no spark
I have a buddy who owns a 89 YJ with 4cyl motor he is getting fuel but no spark to any of the spark plugs. He is looking for some troubleshooting ideas?
midnight_f150 is offline
post #2 of 13 Old 08-25-2011, 08:31 AM
nembudonna
Check the spark control module. It's on the passenger side firewall.
nembudonna is offline
post #3 of 13 Old 08-25-2011, 09:04 AM
Que89YJ
Check the Ignition control module. The ICM. Make sure it has power. It's a high fail part. The fact it has fuel would mean the crank sensor is probably good, but the pickup sensor inthe distributor could be a possibility. I have an 89 and with no diagnostics like the OBDI systems its a little more difficult to nail down. Do you have a meter to do some readings?
Que89YJ is offline
post #4 of 13 Old 08-25-2011, 10:47 AM
Quags
FWIW: Have the auto parts store check the module before spending cash on a new one. From many threads and personal experience, the Crank Position Sensor has been the culprit many many times. I had absolutely zero spark after a transmission change in June. Went through the entire system and ended up being the sensor. They seem to go bad without reason and has happened to a lot of folks here. Replaced it and the jeep cranked up immediately. good luck!!!!
1992 2.5L YJ, Tube bumpers, Hella Lights, Herculined Interior, 33x12.50x15 on 15x8 Soft 8s, and RC 4" Lift.
Public Album
Quags is offline
post #5 of 13 Old 08-25-2011, 03:12 PM Thread Starter
midnight_f150
Thanks guys for the help I will pass this info on to him.
post #6 of 13 Old 08-25-2011, 05:15 PM
Mark05059
even though the fuel pump may be working make sure that the injector itself is squirting fuel. if it isnt and it has no spark its generally the crank sensor.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 13 Old 08-26-2011, 04:00 PM Thread Starter
midnight_f150
I talk to him today and he said that he has already replaced the spark control module. He is going to work on it this weekend and check out the crank sensor. He said thanks for the help and info.
post #8 of 13 Old 08-26-2011, 09:46 PM
Que89YJ
I agree. No fuel from the injector is a bad pick up in the distributor. no spark is usually it bad crank sensor.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #9 of 13 Old 08-27-2011, 04:16 AM
Mark05059
Q when my crank sensor went out I didnt have either spark or fuel at the injector (the fuel pump would run) The pickup in the distributor was fine... changed the crank sensor and all was good again.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #10 of 13 Old 08-27-2011, 06:39 AM
Que89YJ
Yes. Crank sensor ostensibly both injector and spark. Cam is injector. X2 Doing this from my cell is a pita.
Que89YJ is offline
post #11 of 13 Old 08-27-2011, 08:40 AM
Mark05059
ditto
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #12 of 13 Old 09-07-2011, 05:33 PM Thread Starter
midnight_f150
Charlie got it fixed it was the Crank sensor wire. Something chewed the wire to the sensor into. He wanted me to tell all of you thanks for the help and info. He said it started right up and I pulled the clutch in and it went to the floor. He checked the clutch master cylinder and it was bone dry. He is going to work on that saturday but was wonder if yall had any tips for him.
post #13 of 13 Old 09-08-2011, 05:43 AM
Quags
CPS every time!!! LOL
Public Album
Quags is offline
95 yj 4cyl wont start, no spark, no fuel pressure? bigredjeep95 YJ Wrangler Technical Forum 9 10-04-2010 07:02 PM
YJ 4cyl and TJ 4cyl tranny/transfer case swap except the bell housing? whatmud78 YJ Wrangler Technical Forum 4 10-02-2009 09:45 PM
how to change 4cyl spark plugs-instruction/tips? jclaudii TJ Wrangler Technical Forum 20 08-27-2009 12:36 PM
1994 YJ 4cyl no spark Brian79z YJ Wrangler Technical Forum 20 08-31-2008 06:03 AM
4cyl spark plug gap redjeep669 YJ Wrangler Technical Forum 2 01-26-2008 09:31 AM
