Quantcast 89 4.2 won't crank in wet weather? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 89 4.2 won't crank in wet weather?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 02-24-2009, 07:50 PM   #1
wthall
My nephew has an 89 yj with a 4.2 5spd. Sometimes when weather is wet/damp he says engine will spin over but not crank. He has changed dist. cap and it still has same symptoms. Just wondering if anyone had any ideas before I make 40 mile trip to look it over for him.
wthall is offline   Reply With Quote
Old 02-24-2009, 08:34 PM   #2
Old4X
1990 CJ7
Tell him to take a spray bottle. Put 5 or 6 tsp of salt in it and fill with water.
Go out at night, spray down the dist cap, wires and plugs and start it up.
Report back, the problem should be obvious.
Old4X is offline   Reply With Quote
Glock Forum
