89 4.2 problem. Won't go over 50 mph. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 89 4.2 problem. Won't go over 50 mph.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 09-12-2013, 07:14 PM   #1
TJQ
My brother has a bit of a dilemma with his 89 4.2 YJ. Motor ran good. He had an occasional chattering sound which turned out to be the timing chain hitting the cover from time to time. Without any warning, the Jeep just died when he went to pull away from a light. Figured it was an ignition system problem, swapped modules, coils, etc.. Turned out to be the timing chain was so stretched he was able to lift it right off the sprockets, so it probably jumped a tooth (or two).
Changed the timing set, cap, cap base, rotor, plugs, wires, fuel filter. Got it all back together, took some time to get it tuned but eventually got it running smooth again. The coil wire was arcing, but that was fixed with the new wires.
It starts up, idles, drives just as it did before this problem, until you reach 50mph. It runs normal from 0-50, once it hits 51 it falls on its face. He can wind out 1st-3rd like usual. It's like it has a governor on it. Throttle linkage all good, carb is clean. Cat isn't clogged.
He has a Weber 32/36, nuttered, Team Rush mod with MSD 6AL, Ford coil, the plugs and wires are ones recommended in a thread by JEEPHAMMER.
Anybody have any ideas?
TJQ is offline   Reply With Quote Quick reply to this message
Unread 09-12-2013, 09:32 PM   #2
Bergy1
http://www.jeepforum.com/forum/f12/2...-gear-1565299/
Check out this link. I had similar problems.
Bergy1 is offline   Reply With Quote Quick reply to this message
Unread 09-15-2013, 05:48 PM   #3
TJQ
Thanks for the info. He had to order the distributor so hopefully he will have time to mess with it tomorrow evening.
