89 4.2 flooding problems - JeepForum.com
post #1 of 10 Old 06-07-2013, 05:12 AM Thread Starter
vtmtnman
I've got a 1989 Wrangler with the 4.2 engine, with a Holley remanufactured Carter BBD carb. Last week it started flooding badly going up hills (and hills are everywhere here). And when I say flooding it's bad, it takes a lot of time cranking with the throttle wide open to clear it, spits out black smoke, etc.. What's driving me crazy is it didn't do this the first couple months I had it this year. It went up these same hills just fine. It would slow down a bit but would get up them at reasonable speeds. The only two things that happened recently were I replaced the valve cover gasket and cleaned the rockers and pushrods up of the oil sludge caked on them 2 weeks ago, and shortly after that I took it up a very nasty trail. Hitting some bad bumps (no choice but to throttle it through some mud) I noticed it sputtering some but it didn't die. I don't think anything happened when I worked on the gasket/rockers because when flat the engine runs fine even when revved up to high rpms.
Could that bumpy trail have bumped something off with the carb? The float seems like it's at the right height (stock specs anyhow). Is there anything except the carb that could be doing this? I could really use some suggestions for what to do here, I don't have a huge budget either, and I hate driving a loaner car to work...
vtmtnman is offline
post #2 of 10 Old 06-07-2013, 05:57 AM
Rproject
1987 YJ Wrangler
Holley remanufactured your Carter BBD?
If you have the Carter carb, all I gotta say is ------ that thing sucks on hills. While off roading, I would continually have to feather the gas to keep it from starving on the down hill. Switched to a Motorcraft and the problem went away.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 10 Old 06-07-2013, 06:04 AM Thread Starter
vtmtnman
Yeah, there's a sticker that says Holley Remanufacturing on it. It's definately the BBD carb.
If the only possible source of this problem is the carb I guess I'll have to get a different carb (I did some reading on the forum here on the MC 2100). I just want to be sure it's nothing else before I start throwing money at it.
vtmtnman is offline
post #4 of 10 Old 06-07-2013, 06:30 AM
Rproject
1987 YJ Wrangler
Yeah, my Carter worked perfectly on flat land (which we have plenty of here in the Midwest), but get her off camber and she's a pig. I had to readjust mine monthly, even after I had a guy rebuild it for me. For the $2-300 it costs for an upgrade to the Weber or Motorcraft, it's WELL worth it. The reduced maintenance time alone is worth the investment.
1996 White ZJ
Rproject is offline
post #5 of 10 Old 06-07-2013, 04:55 PM
jay-h
Sounds like your float/float valve is damaged or stuck open. Usually an easy fix. Bad bumps can sometimes damage the valve or bend the float arm
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is online now
post #6 of 10 Old 06-07-2013, 05:51 PM
Old4X
1990 CJ7
^^ This. Pull the top off and check, no need to remove the carb.
Check the float for leaks, usually done by weighing it.
I have 220,000 miles on BBD carb on this jeep, it gives me good service.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 10 Old 06-08-2013, 05:59 AM Thread Starter
vtmtnman
I'll have to check that. I did lower the float a bit but it didn't help. I didn't check the inlet valve.
vtmtnman is offline
post #8 of 10 Old 06-08-2013, 08:59 AM
act3k
You should check your stepper motor and vacuum lines, your stepper controls the air fuel ratio and can cause a lot of issues. I had a horrible flooding problem so I bought a MC2150 off eBay for 100 bucks and an adapter plate and it works amazing now. Personally I would junk that BBD
act3k is offline
post #9 of 10 Old 06-08-2013, 09:59 AM Thread Starter
vtmtnman
Yeah I think even if I get it working, I'll replace it eventually. It's a lot more complicated than it needs to be.
vtmtnman is offline
post #10 of 10 Old 06-08-2013, 10:14 AM
superj
Yup. Get an intake and a four barrel and be happy
I don't feel like working on anything at this time so i sold my yj.
superj is offline
