89 4.2 to 96 XJ 4.0 Swap Thread w/ wiring - Page 3 - JeepForum.com
post #31 of 42 Old 11-29-2010, 08:48 PM Thread Starter
green89yj
I will respond here again.
I am running both the upstream and downstream O2 sensors.
Just some useful information: I think we need to have about 34 psi on the fuel rail.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #32 of 42 Old 12-07-2010, 09:35 AM
five-string
Update...
jeep is running!
I have about 3 codes to deal with and a possible idle stepper problem (high idle) but wow! What a difference! Lots more power. And I am hoping better fuel economy.
Boycott shampoo! Demand the REAL poo!
White Jeep Club #119
☼lllllll☼
five-string is offline
post #33 of 42 Old 12-07-2010, 10:08 AM
remmons
Originally Posted by five-string View Post
Update...
jeep is running!
Great Job! We love to hear good news around here!
Robert.
remmons is offline
post #34 of 42 Old 12-16-2010, 06:37 AM Thread Starter
green89yj
let me know what you find on the high idle because my high idle only kicks in after the Jeep is warm. Right when i start it it idles like crap. What codes are you throwing?
post #35 of 42 Old 12-16-2010, 07:46 AM
five-string
Well, as it turns out, the high idle appeared after I thoroughly cleaned the throttle body. It seems all the crud in there was blocking the air flow at idle. When I removed all that dirt, air was able to move around the edges of the butterfly plate and the idle speed increased. When I held a finger on the edge of the plate it would block the leaking air and idle dropped.
I loosened the two screws and adjusted the plate so it closed better, adjusted the set screw for idle speed and I got the idle down to 800-900 rpms.
It still idles like I have a huge cam in it when I first start it up. And it goes right to the 800-900 rpms immediately which I think it should run faster at cold start up, shouldn't it? Then after about 30 seconds it settles into a smooth idle. I haven't checked codes lately. But what baffles me is the Jeep doesn't start up or run any different after I clear the ecm by disconnecting the battery. It seems it is not learning anything over time. Does my ecm have a learning disability? I would really like to figure out this rough cold idle problem.
Edit: I am only running the upstream o2 sensor. I don't have a cat or second o2 sensor bung.
☼lllllll☼
post #36 of 42 Old 12-21-2010, 10:07 PM Thread Starter
green89yj
I would try to run that second o2 sensor. Is there any way for you to post up a video? I think mine is doing something similar.
post #37 of 42 Old 12-22-2010, 11:54 PM
GAT72991
Just in case you are still having problems with that lock cylinder, here's a good link i found a while back on steering columns...mainly to tighten them up but has awesome instructions to get to/remove the lock cylinder...etc.
BC4x4.COM four wheel drive, 4x4, offroad and fourwheeling site.
GAT72991 is offline
post #38 of 42 Old 12-23-2010, 01:06 PM
five-string
I recorded a vid but the sound is not the best for hearing the rough idle. I will try again, concentrating on the exhaust.
☼lllllll☼
post #39 of 42 Old 12-24-2010, 04:49 AM
dodger889
Oh just incase you don't not know a fI engine will idle about the same rpm cold or hot. Not like a carbed engine that has to have a higher idle speed for over coming a choke.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #40 of 42 Old 01-09-2011, 09:17 PM Thread Starter
green89yj
Right, but right when they start up don't they run high for a couple seconds just to warm up a little.
post #41 of 42 Old 01-10-2011, 07:35 PM
dodger889
If I think about it is just a touch higher but only a couple hundred rpm. Not really enough to call it high.
post #42 of 42 Old 02-15-2011, 06:20 PM Thread Starter
green89yj
Not like a 1800 RPM high idle but noticeably higher.
I'm still having very similar symptoms and haven't had time to trouble shoot.
242 , 4.0 , 4.0 swap , asd , wiring diagram
8.8 Swap Into TJ Build Thread GreenJip TJ Wrangler Technical Forum 154 04-14-2011 04:30 PM
Another 4.0L swap wiring thread Drdan524 YJ Wrangler Technical Forum 0 04-19-2009 07:00 PM
New Wiring Harness Thread Good JK Wrangler Technical Forum 8 05-08-2007 08:31 PM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 12:33 PM
2.5 to 4.0 swap thread... redjeep669 YJ Wrangler Technical Forum 4 11-29-2006 09:02 AM
