89 4.2 to 96 XJ 4.0 Swap Thread w/ wiring - Page 2 - JeepForum.com
post #16 of 42 Old 04-03-2010, 10:19 PM Thread Starter
green89yj
What Bastidjeep is saying, is that you have to use a 4.0 flywheel, unless you want to pay out the rear for Hesco's kit to relocate the CPS
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #17 of 42 Old 04-03-2010, 10:21 PM Thread Starter
green89yj
Hey, I managed to start and run it today for like 5 minutes with no cutting or splicing really required ha. Yesterday I went to the Pick and Pull Junkyard and got some under dash stuff from a 96 XJ and hooked it up to the bulkhead connector and started it, just cause I needed the moral boost.
post #18 of 42 Old 04-05-2010, 10:36 AM
remmons
Originally Posted by Bastidjeep View Post
When I did my conversion all I did was that I left the original bulkhead plugs of the YJ on both sides. I labeled everything and left 1 ft long pigtails on the YJ wiring. I then soldered and heat shrank all the necessary wiring in the conversion. The only 2 wires I ran through the center bulkhead rubber plug was my check engine light wire and fuel pump wire. green89yj, somewhere along the line I think you are going to have to cut and splice wiring. I think if you can post some pictures it may give all of us a better understanding of exactly what you are doing and may be able to steer you in the right direction.
Thus far, I only had to cut and splice one wire. It was for the Tach. I removed it from one cavity and tried to install it into another cavity, the cavity was for a smaller plug.
I haven't verified this yet, but I had discovered that the fuel pump wire (orange) was already there. It appeared that the 2.5L EFI harness was also used for the 4.2L carbed, with the necessary changes i.e. lack of electric fuel pump on 4.2L. I haven't verified this yet, but I did trace down this wire to an empty relay plug. Could be as simple as plug-and-play under the dash? I will run a test on it this week to see.
Robert.
remmons is offline
post #19 of 42 Old 04-05-2010, 06:05 PM
SkullTripper
1987 YJ Wrangler
Where can I find one of those? and how do I know which tranny I have or do 87s all come witht he same ones? 87 4.2 auto 3spd and will the 4.0 flywheel bolt right up?
Its a Jeep thing....
My 1987 Jeep Wrangler Build..
SkullTripper is offline
post #20 of 42 Old 04-05-2010, 06:27 PM Thread Starter
green89yj
that will probably be the BA-10-5 which is pretty much junk. You might try finding an AX15 from a 4.0 jeep that would have the right flywheel already, the only issue is that your T-Case might not have the right input shaft to match up with the tranny
post #21 of 42 Old 04-05-2010, 07:03 PM
SkullTripper
1987 YJ Wrangler
yeah I don't have that kind of money... I'll be doing good to afford the new flexplate... my wifes car jsut broke today I got home and noticed it smoking open the hood and oil everywhere barely had any in it... so I'm SUPER broke plus with college comin up will a 4.0 flexplate bolt right on?
post #22 of 42 Old 04-05-2010, 08:57 PM
Bastidjeep
For you automatic guys I do not know that answer. I am sure someone on here can give you the correct one.
Bastidjeep is offline
post #23 of 42 Old 04-06-2010, 10:39 AM
remmons
I don't have the answers for all autos that came in the Jeeps, but This I can say.
A 4.0L flex plate will bolt in place of the original 4.2L. What will be needed is one of two things. 1, get an auto tranny that came out of a 4.0L Jeep (YJ or XJ Cherokee). 2, there is a way to adapt a CPS onto a bell housing that did not come with this provision. I do not have the link handy, but a search on CPS conversion should help you closer to what you're looking for. This search will also yield answers regarding the starter issue, if there are any.
Good luck!
Robert.
remmons is offline
post #24 of 42 Old 04-12-2010, 06:46 PM Thread Starter
green89yj
Well. I drove it yesterday. I have given up all hope of using the 4.2 steering column and will probably just incorporate the ignition switch into a flat dash and maybe the turn signal somehow.
post #25 of 42 Old 04-13-2010, 10:07 AM
remmons
I am curious. What trouble are you having with the column? I remember you had some trouble with the lock cylinder.
Robert.
remmons is offline
post #26 of 42 Old 05-02-2010, 04:38 PM
Project_Sparta
Im fixing to do a project like this, My brother has a 89 Xj with a blown motor with a bad tranny, but a rolled 96 xj with all parts necessary, But I really dont know if I need to take the whole harness out of the 96, they are both 4.0 as far as I know I do know the 96 is HO. someone told me the harness on the 89 did not have the right connections and abandoned the project.
Project_Sparta is offline
post #27 of 42 Old 06-13-2010, 09:09 AM Thread Starter
green89yj
the 89 is a Renix injection system as well as OBDI instead of OBDII.
post #28 of 42 Old 11-17-2010, 07:59 PM Thread Starter
green89yj
Hey, been getting some questions so I will post up some new stuff and open this back up to contribution.
Sorry it slacked off but school started and English 1101 means lots of writing.
post #29 of 42 Old 11-18-2010, 07:07 AM
remmons
We understand how things go, especially with the holidays coming up. Good luck!
Robert.
remmons is offline
post #30 of 42 Old 11-18-2010, 08:37 AM
five-string
I'm the question guy. Ohh! Ohh! Ohh! (five-string waves his arm wildly in the air from the back of the classroom)
I'll post some of my questions here for other's benefit...
1. Are you running the stock xj fuel pump? I have discovered the '96 is unique because it it the only year pump to have a built-in regulator right on the pump so no return line is needed from the fuel rail.
2. Are you running one or two O2 sensors? If just one, do you have to do anything to trick the ECM into thinking there is a second one downstream present?
FYI, I am working on a '90 Yj that I have installed a 4.0 HO head on, (ported, polished, otherwise stock everything) and am in the process of getting the wiring, MPFI, ECM, etc all hooked up. The donor was a '90 XJ that had a '96 motor installed by PO. OBDII system. The XJ ran well before I pulled the motor. That alone tells me the OBDII system can be made to work in older vehicles, unlike many posts I have read saying the OBDII system is too difficult to work with.
Boycott shampoo! Demand the REAL poo!
White Jeep Club #119
☼lllllll☼
five-string is offline
242 , 4.0 , 4.0 swap , asd , wiring diagram
8.8 Swap Into TJ Build Thread GreenJip TJ Wrangler Technical Forum 154 04-14-2011 04:30 PM
Another 4.0L swap wiring thread Drdan524 YJ Wrangler Technical Forum 0 04-19-2009 07:00 PM
New Wiring Harness Thread Good JK Wrangler Technical Forum 8 05-08-2007 08:31 PM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 12:33 PM
2.5 to 4.0 swap thread... redjeep669 YJ Wrangler Technical Forum 4 11-29-2006 09:02 AM
