88yj guages - Page 2 - JeepForum.com
post #16 of 19 Old 02-24-2013, 11:45 AM
voz
1sas?
VOZ™
voz is offline
post #17 of 19 Old 02-25-2013, 08:40 AM
Que89YJ
1sas? What does that mean?
Que89YJ is offline
post #18 of 19 Old 02-25-2013, 09:22 AM
Berniebikes
Voz, to answer the question fuel gauge is 0 empty and 90 full if you plan on using the existing sending unit. The autometer is not plug and play. you will have to rig some mechanism to hold the gauges in place, and will not be able to use the printed circuit for signal and power with the new gauge. There is an aftermarket gauge cluster back plate (it fits into the dash like the stock plastic piece) that you can purchase, and then all you need to do is wire things up, but you will also have to make certain that the sending units are all matched to the gauges.
Here is the autometer gauge panel for YJs from JEGs
http://www.jegs.com/i/Auto+Meter/105...FUWd4AodhBEAFg
Berniebikes is offline
post #19 of 19 Old 02-25-2013, 02:31 PM
voz
I have seen that panel, but I was hoping to get a Double D or Youngjeeper11 designed dash.
I would like to use my 92 4.0 sending units if possible
VOZ™
voz is offline
