88yj guages - JeepForum.com
post #1 of 19 Old 07-16-2012, 07:55 PM Thread Starter
88YJRay
88yj guages
Where can I get cheap factory replacement gauges? Or would it be better/cheaper to get after market? My tac and speedo work ok but
My trip meter button has fallen out of the gauge. You can still reset the trip meter you just have to stick it in the hole the rift wAy. At this point I need my trip meter cause the gas gauge does not work along w/ the oil pressure, the temp gauge is intermediate. But the clock still works. Any thoughts would be appreciated. Thanks!
Ray
88YJRay is offline
post #2 of 19 Old 07-16-2012, 08:43 PM
scubamc
For factory check ebay, Craigslist, junkyards and the classified on here. It's better to go with aftermarket gauges but they will not be cheaper. Have you tried cleaning the contacts on the back of your gauges?
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 19 Old 07-17-2012, 02:22 AM
justplayinround
I had to replace my gauges on my 91.. I went with the gauge pad from quadratec....about 40.00 then bought all autometer gauges for it... Not cheap at all but an awesome replacement!! I had no luck finding factory replacement gauges that either matched my dash color, or all worked. Good luck!
justplayinround is offline
post #4 of 19 Old 07-17-2012, 03:54 AM Thread Starter
88YJRay
Ok, cool thanks!
Ray
88YJRay is offline
post #5 of 19 Old 07-17-2012, 05:17 AM
1SASjeepster
When my volt meter went out in my YJ, I called up the dealer and they wanted $150 JUST FOR THE GAUGE!! I then decided to go with Autometer gauges which go for around $50 a piece. I also wanted to get rid of the plastic dash, so I did. I have enclosed my new dash. It isn't finished, but it is close.
Autometer gauges are cheaper and last longer. They are also much more easier to replace than the OEM units BUT if time is a problem and you want to keep your factory plastic dash... "justplayinround" advice and try that route or eBay. It will be the fastest way to get you up and going.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #6 of 19 Old 09-30-2012, 12:55 PM
voz
I was attempting to install LED's on my Dash, I need new gauges, they look ****ty...
I like the center gauge cluster w/autometer gauges on Quad website.
Are the Autometer gauges plug and play? Just remove OEM's and Install new?
I have an 89
VOZ™
voz is offline
post #7 of 19 Old 09-30-2012, 01:03 PM
voz
Which one?
0 Ω empty / 90 Ω full (Electrical)
240 Ω empty / 33 Ω full (Electrical)
73 Ω empty / 8-12 Ω full (Mechanical)
Fuel Gauge has three choices
VOZ™
voz is offline
post #8 of 19 Old 10-02-2012, 06:12 AM
swaveman
I'm curious about this as well. My dash is beat to crap and most of my gauges dance while driving down the road. Any updates?
swaveman is offline
post #9 of 19 Old 10-02-2012, 06:24 AM
swaveman
Everything I have seen aside from the speedometer shows that it is just a quick plug-n-play setup. The manual on quadratec has the same thing. Here's the link:
http://www.quadratec.com/Assets/Installation/61277.pdf
swaveman is offline
post #10 of 19 Old 10-04-2012, 05:39 PM
voz
voz is offline
post #11 of 19 Old 10-16-2012, 07:59 PM
swaveman
Originally Posted by voz View Post
Great! More cool stuff to add to my wish list. The wife is not going to be happy.
swaveman is offline
post #12 of 19 Old 02-24-2013, 07:01 AM
voz
Still have not found my answer on fuel gauges
VOZ™
voz is offline
post #13 of 19 Old 02-24-2013, 07:03 AM
Fuddmaster
My wife is never happy when I start talking jeep!
Fuddmaster is offline
post #14 of 19 Old 02-24-2013, 07:16 AM
voz
Fudd, I'm lucky I guess, Wifey does not mind, she wants my build finished to we can ride!
VOZ™
voz is offline
post #15 of 19 Old 02-24-2013, 09:22 AM
90DesertTanYJ
Most likely its just the plastic copper pathway dealie that ties the gauges together and provides input. These a notoriuos for failing, If you clean up the contact area on everything you might have some success. If not you can get a better aftermarket one on eBay for about $80. If you have simple wiring skills you can hardwire the gauges to the dash harness connector. It solved all my issues but I fried my volt meter by accident. I have a few pics if your feeling froggy and want to try.
Or you could go with 1SAS and get ya some new ones! Awesome set up!
90DesertTanYJ is offline
