88wrangler gas gauge not working - JeepForum.com
post #1 of 13 Old 01-02-2009, 01:15 AM Thread Starter
DirtyDanNY
hey i have an 88 wrangler that sat out in the rain for about 2 years with no top on it i've been fixing it up but havent been able to fix the gas gauge i noticed the other day tho if i touch the screw on the back of the gauge it moves around and was wondering if a bolts suposed to go on the back of it
-Thanks
DirtyDanNY is offline
post #2 of 13 Old 01-02-2009, 06:45 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Pull the cluster.
On the back it's got a plastic flexible circuit map. Use a pencil eraser to clean up all the contacts.
It's prolly just got dirt and green stuff from moister on it.
30 minute job.
- Ernie
Richmond88yj is offline
post #3 of 13 Old 01-04-2009, 11:37 PM Thread Starter
DirtyDanNY
thanks i'll try that in the morning
post #4 of 13 Old 02-13-2009, 11:58 AM Thread Starter
DirtyDanNY
alright gas gauge still doesent work and im tired of hopeing i filled up the 1 gal in the trunk i called around to a few junkyard near me and nobody had the cluster for a yj
-questions
-i picked up a Sunpro gas gauge and wanted to rig that up but before i opened it i read something about a sending unit -has anyone ever intalled one of these/is it worth it or should i stick it out n try n find a cluster
-can i use a diff cluster from another year -how hard is the swap
Thanks
post #5 of 13 Old 02-14-2009, 02:50 AM Thread Starter
DirtyDanNY
huh??? anybody got anything???
post #6 of 13 Old 02-14-2009, 03:26 AM
docneon
You had me UNTIL hello
docneon's Avatar
1987 YJ Wrangler
couple of things to check. If you can get to the wiring that leads to the back of the cluster, use a multi-meter to check the resistance of the tan wire. the YJ sending unit is 0 ohms empty, 88 ohms full. if you are not getting any reading or something outside of this range, chances are you have a bad sending unit. from what I've been abel to tell, there aren't any aftermarket sending units that will just drop into the YJs tank.
FWIW, YJs are notorious for bad gas gauges/sending units. Best bet is to fill it up and keep doing so every 180 miles or so. I set my trip odometer at every fill up and figure out my milage.
Originally Posted by Bhelliom
I assumed this thread was going to be something completely different.
I was sorely mistaken
l _____
/l ,[_\_\],
l---L []lllllll[]-
()_) ()_)
---o-)_)
docneon is offline
post #7 of 13 Old 02-14-2009, 03:40 AM Thread Starter
DirtyDanNY
thank you im gunna check that tomarro i hope its not the sending unit -anybody got anything on if any other clusters will work i hate the guessing game and i cant always fill the tank i try n put $10 in every other day i dont drive it far just tring to make it more driveable
Thanks
post #8 of 13 Old 02-14-2009, 09:10 AM
bigbelman2009
you can get a sending unit from jcwhitney.com
bigbelman2009 is offline
post #9 of 13 Old 02-14-2009, 09:23 AM
cableguy01960
I believe the cluster from 87 - 91 is the same it may be 87 - 95 but not sure after the FI was added. Hope this helps. Most here have made peace with there dysfunctional gas gage mine stays on full for a while then when it gets to about a quarter tank I am empty. I carried around a small gas can at first until this was consistent data.
cableguy01960 is offline
post #10 of 13 Old 02-14-2009, 09:39 AM
lilBlackXJ
87-91 is the years that will interchange iirc.
- 1998 Jeep Cherokee XJ -
K&N filter, removed swaybars, 7" 6000k HID AUX lights.
Little innocent looking Jeep, geeting lockers and a budget boost soon.
lilBlackXJ is offline
post #11 of 13 Old 02-14-2009, 09:45 AM
Justincredible
I've got the same problem and just figured out I can get 220 mi. out of a tank, so i fill up at 200. I'm pretty sure I ned a new sending unit as well but will try the pencil eraser trick first.
Justincredible is offline
post #12 of 13 Old 02-14-2009, 10:23 AM Thread Starter
DirtyDanNY
Thanks guys i think i might just go with the aftermarket gauge if there such a hastle i dont wanna spend money at the junk yard and have the same problem
post #13 of 13 Old 02-14-2009, 10:33 AM
bigbelman2009
Gas Gauge Not Working HELP PLEASE trailmaker YJ Wrangler Technical Forum 15 08-01-2010 10:18 AM
Gas Gauge not working bshae342 YJ Wrangler Technical Forum 5 11-08-2009 06:05 PM
88Wrangler reservoir cap drv4shw YJ Wrangler Technical Forum 1 08-26-2008 09:48 PM
98 TJ gas gauge not working viclava TJ Wrangler Technical Forum 9 04-08-2007 10:31 PM
Gas Gauge not working hipsinking YJ Wrangler Technical Forum 9 06-15-2004 11:55 PM
