88 yj wiring help - JeepForum.com
post #1 of 6 Old 10-01-2011, 09:24 PM Thread Starter
72tex
88 yj wiring help
i have an 88 yj with a 4.2 the engine compartment harness is shot and i cant find another one. any ideas on swaping it with some other models harness?
72tex is offline
post #2 of 6 Old 10-01-2011, 11:40 PM
4.7stroker
Well the first choice would be from a Cherokee.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 6 Old 10-02-2011, 05:53 AM
Berniebikes
Later CJ's would be nearly the same for the engine, wiring into the inside would be different
Berniebikes is offline
post #4 of 6 Old 10-02-2011, 07:25 AM
staush
look on e-bay under yj parts and they usally have some in their that have been checkedout for a reasonable price
staush is offline
post #5 of 6 Old 10-02-2011, 07:34 AM
raynmaker
what part is shot? Making your own is easy enough. The trick is to take your time and do it neat. If you come across connectors you need most jeeps and some dodges will have identical parts.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #6 of 6 Old 10-02-2011, 07:34 AM
Old4X
1990 CJ7
Any 6 cyl CJ or YJ from 1978 to 1990 would work.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
THIS WIRING STUFF SUCKS!!! wiring problems dwdrums40385 YJ Wrangler Technical Forum 2 12-09-2010 07:30 PM
need wiring help! tbenne6 YJ Wrangler Technical Forum 4 11-02-2007 04:58 PM
Where does Trailer Wiring Kit Splice into existing wiring on YJ gary1 YJ Wrangler Technical Forum 1 07-18-2005 04:03 PM
Wiring Windshield Mounted Lights .... Need Stock Wiring Colors ..... JHyett TJ Wrangler Technical Forum 9 03-22-2005 08:14 AM
IPF 968's... factory wiring or kit supplied wiring? thejafe TJ Wrangler Technical Forum 4 01-31-2005 09:04 PM
