88 yj steering column - JeepForum.com
post #1 of 3 Old 11-29-2008, 03:04 PM Thread Starter
88yjpos
I need a detailed teardown and drawing of a 1988 yj steering column. There is a metal key that moved the ignition switch rod back and forth that broke. Not sure how to take the tilt mechanism apart on the lower column.
Can anyone help? The Hayes manual is wothless for this type of repair.
88yjpos is offline
post #2 of 3 Old 11-29-2008, 06:07 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Can this help you? having trouble with posting an image link give me a minute.....or three.
[IMG]http://ho*******cast.net/~laybackman/pg1.jpg[/IMG]
[IMG]http://ho*******cast.net/~laybackman/pg2.jpg[/IMG]
remove ******* and place; me(dot)com between ho and the cast.
OK, is this the JF censor kicking in here? If so, ?????
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
Last edited by laybackman; 11-29-2008 at 06:42 PM. Reason: $#@#@%@*$%$(@ comcast!!
laybackman is offline
post #3 of 3 Old 12-01-2008, 07:26 PM Thread Starter
88yjpos
Thanks for the help
88yjpos is offline
Something in my steering column broke loose. I have no steering Swampwalker3 YJ Wrangler Technical Forum 5 11-06-2009 06:08 AM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
New Steering Column fixed sloppy steering. Oman Jeep TJ Wrangler Technical Forum 5 09-23-2008 01:59 PM
Steering column Mr YJ YJ Wrangler Technical Forum 3 09-15-2006 05:01 PM
XJ steering column in YJ??? dhillier YJ Wrangler Technical Forum 5 11-02-2004 09:36 PM
