88 yj steering adjustment - JeepForum.com
post #1 of 13 Old Today, 04:50 AM Thread Starter
jxgrab
Hi,
I have been researching this issue without finding a good answer. My 88 YJ has a 3-4" shackle lift with 31"x10.50 and it has the extended pitman arm. My question is should I leave any play in the steering? Most lifted vehicles I have driven have some play and I adjusted my YJ so there is about 1/4" of play in the wheel when driving but I don't feel any at below 10mph. Should I give the adjustment screw another nudge or am I already good at where I have just a little play at driving speed?
jxgrab is online now
post #2 of 13 Old Today, 08:50 AM
Jeepsr4me
You should not mess with that adjustment.. Those boxes RARELY need any adjustments. If they are worn to point you think it needs adjusting then it needs replaced.
Also Not sure why you have drop pit and 4" shackle lift... Just a disaster waiting to happen.
Unless this is just a hunting rig or mud truck then I would save up and get a real lift even if its just a cheap RC lift and throw those lifted shackles in garbage.
Also you need to download the FSM and any adjustment of that box is in there. Check any joints on the steering rod and all steering linkages. Any worn parts replace.
Also Take the trac bar off and make a tent stake out of it,.
Post pics of the front of your jeep.
Jeepsr4me is online now
post #3 of 13 Old Today, 10:20 AM Thread Starter
jxgrab
I attached some pictures.
Everything seemed really tight in the front end, the Jeep came with 33" MT and I just put new 31" AT on it and did an alignment last week.
I haven't had a Jeep before and I am use to driving performance cars with speed sensitive steering so the sterring might be in spec for the setup, the Jeep is only for snow days it is a 3rd vehicle, but I would like it tuned as well as it can be without throwing thousands of $ at it
I am not sure if I used the term shackle lift correctly but it looks like the front shackles and rear shackles are extended.
Any advice for a better setup is appreciated
post #4 of 13 Old Today, 10:28 AM
Randonexplosion
Randonexplosion's Avatar
Sloppy steering can be a result of lifting a vehicle on the cheap. Using lift shackles rotates your axle and takes away the caster angle that is necessary for good alignment/steering. My Jeep steers better than it did when it was almost stock, but my steerng is ar from stock as well.
Short answer, no, don't "build in" any slop/slack into your steering.
Randonexplosion is offline
post #5 of 13 Old Today, 11:43 AM
puppybreath
they look like stock length shackles to me. If you can adjust to a 1/4 inch of play, then I'd say the front end is good, there should always be a small amount of play in the wheel, 1/4 inch at the steering wheel rim is normally good. If you're used to rack and pinion, they're always tighter than recirculating ball type.
If it feels mushy, check elsewhere, sit in front and have someone rock the wheel, look for play anywhere. Loose bushings in the rear end can also produce play in the steering
puppybreath is offline
post #6 of 13 Old Today, 11:59 AM
Jeepsr4me
That is a suspension lift with GOOD replacement shackles NOTHING WRONG WITH THAT AT ALL..
Your track bar is still there and if not required by the inspection nazis take it off.. It will improve the ride by a lot. As is right now that track bar is fighting the springs in the up and down movement.
Huge thread on removing.. Heck even if you have inspections, take off and keep till needed.. I painted your pic to show the bar..
post #7 of 13 Old Today, 12:02 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Those shackles aren't OEM, but they don't look like much of a lift if any. My "lift" shackles are 5 1/4" from the center of the top bolt to the center of the bottom bolt. And they're only 5/8" lift. You do probably have a 2-3" lift kit on there. So the dropped pitman arm looks right for it. If you already did an adjustment on the gearbox, I wouldn't do it again. Try removing your track bar and see if that helps. If you live in a state that requires a track bar, you may have to put it back on for inspections. Then double check your alignment.
Love that "beaver teeth" pic.
Edit: I guess Jeepsr4me and I were posting at the same time.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #8 of 13 Old Today, 12:04 PM Thread Starter
jxgrab
Thanks for all the tips fellas and looking over my suspension and letting me know what I have.
...and I will look up the track bar delete thread and maybe do it this weekend. Then report back
post #9 of 13 Old Today, 02:57 PM
Chrisnvegas
Chrisnvegas's Avatar
Removing the trac-bar will not improve steering.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #10 of 13 Old Today, 03:18 PM Thread Starter
jxgrab
Hi,
I got home from work and removed the track bar. Amazingly, the little bit of play I was feeling driving at normal speed is gone now and driving under 10 miles an hour the steering is so much lighter now. The trackbar looks like it has a extension bracket for the lift kit, which the bracket is loose and moves but the bolt is tight holding the bracket on, it is circled in the picture. I couldn't get this piece off because my 19" deep socket has a split and I wasn't strong enough to brake it loose with a wrench where it is at. I will get a new socket tomorrow and get it off. However, I think this loose bracket might have been binding and been the real issue I had driving at normal speed but the steering feels overall better without the trackbar too.
Thank you all so much, very easy fix
post #11 of 13 Old Today, 03:57 PM
Jeepsr4me
Good deal.. When some one takes the advice is great. Cause I have butted my head against wall with some folks. I tell they exactly whats wrong and they keep chasing their tails with other symptoms.
That bracket is ok to leave there as long as its not going to hit anything. If you go offroading. Remove your sway bar links and tie up the bar. The jeep will be like a mountain goat in comparison to with the bar hooked up
post #12 of 13 Old Today, 04:02 PM
Mr.B
Mr.B's Avatar
Ha!
Ham license:
Everyone is Welcome
Mr.B is online now
post #13 of 13 Old Today, 04:11 PM Thread Starter
jxgrab
Thank you again.
It is my first Jeep and it is just as fun as working on it as my motorcycles. I never thought I would feel that way about a four-wheel vehicle.
Jeepsr4me , jxgrab
