88 YJ starter relay wiring diagram - JeepForum.com
post #1 of 6 Old 12-28-2008, 04:01 PM Thread Starter
brianOU
does anyone have a wiring diagram for a starter relay handy? i have the square relay with 4 posts and 1 stud for the battery hookup. i need to know what wires go where. thanks.
brianOU is offline
post #2 of 6 Old 12-28-2008, 04:27 PM
rwfabworks
Ask and ye shall receive:
rwfabworks is offline
post #3 of 6 Old 12-28-2008, 04:44 PM Thread Starter
brianOU
thanks a bunch.. thats what i was looking for!
brianOU is offline
post #4 of 6 Old 06-14-2010, 04:40 PM
Jabo
I know this is an old thread but if you hook up the battery where it is shown in the picture, where does the wire for the starter come from?
Jabo is offline
post #5 of 6 Old 06-15-2010, 07:42 AM
Que89YJ
See if this post helps. http://www.jeepforum.com/forum/f12/y...oblems-372159/
One more: http://www.jeepforum.com/forum/f12/8...-relay-558255/
Que89YJ is offline
post #6 of 6 Old 01-30-2012, 09:48 PM
reeves_yj_88
My positive terminal has two wires, a heavy gauge and a medium gauge. If I'm not mistaken the heavy gauge wire goes directly to the starter solenoid, the smaller wire goes to the battery terminal on the relay. Then there is a yellow wire from a contact below the batt terminal on the relay that goes to another terminal on the solenoid. Turn the key, close a circuit, starter goes.
I thought it was common knowledge, you don't buy a YJ because you're broke... You go broke because you bought a YJ!
reeves_yj_88 is offline
Need Help with Starter Relay Wiring WarPony YJ Wrangler Technical Forum 22 12-02-2013 06:33 AM
1987 2.5: starter relay wiring ? hints and tips anyone ? intenseblu YJ Wrangler Technical Forum 8 05-08-2009 09:07 AM
Starter Relay Wiring - Ground Wire Question DocArt YJ Wrangler Technical Forum 4 03-06-2009 06:41 PM
95' yj starter relay wiring diagram jws1961 YJ Wrangler Technical Forum 3 03-26-2008 06:29 PM
88 Wrangler Starter Relay Wiring alex88 YJ Wrangler Technical Forum 2 07-20-2004 08:52 PM
