88 YJ Stalls at Stops - JeepForum.com
post #1 of 8 Old 07-21-2013, 09:52 AM Thread Starter
sislvers34
I've got an 88 jeep wrangler with 258 engine that was just completely rebuilt a little over a year ago. I've also ditched the carter carb and gone with a weber about 3 months ago, but continue to have the stalling issue. When u first start out u are guaranteed that the motor will stall at the first red light or stop sign u come to. It starts back up on the first turn. I've scratched my head till I've got no more hair trying to fix this annoying little gremlin. Any advise would be greatly appreciated.
sislvers34 is offline
post #2 of 8 Old 07-21-2013, 04:40 PM
Tyler980
Mine has the same problem, people have told me it could be a vacuum leak.
Tyler980 is offline
post #3 of 8 Old 07-21-2013, 05:24 PM
WV95YJ
WV95YJ is offline
post #4 of 8 Old 07-21-2013, 08:28 PM
Old4X
1990 CJ7
First, check torque on hold down bolts and any adaptors you had to use to put that carb on the manifold.
Next check torque on the intake manifold.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 8 Old 07-22-2013, 04:13 PM Thread Starter
sislvers34
I didn't do the install of the carb so what is the correct torque on the adapters and intake manifold.
post #6 of 8 Old 07-22-2013, 04:16 PM
CrawlingForward
Carbed models don't have an Idle Air Controller, do they?
Edit: sarcasm didn't really come across.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #7 of 8 Old 07-22-2013, 05:04 PM
Cashcrazy
1983 CJ7
I had good luck finding vacuum leaks with a can of electrical cleaner. With the engine running I sprayed the base of the carb and where the intake bolts to the head. The RPM will slowly increase if there is a leak. I found two manifold leaks and one at the base of the carb like this.
Cashcrazy is offline
post #8 of 8 Old 07-22-2013, 05:15 PM
Old4X
1990 CJ7
The OEM BBD does kinda/sorta have an idle controller, the computer uses the sol-vac for that in some circumstances.
Old4X is offline
