88' YJ radio wiring colors are diff. than others.. help? - JeepForum.com
post #1 of 13 Old 10-31-2013, 02:10 PM Thread Starter
JeepingShtHpns
I took my radio out cause it was not and how can you enjoy a nice drive with out some tune.
The PO made a mess behind that stereo system so I just clipped all the wires so I can reconnect them properly. I did a lot of jeepsearch and I don't have all of the same colors like all the ones I found. Can someone help me out?
These are the wires I have to work with coming from the jeeps harness. There is 13 and I numbered them from left to right. And what I THINK the wire is.
1.) black - ground or (-)left speakers
2.) brown/white - left speakers
3.) green - left speakers
4.) green/white - left speakers
5.) purple/white - (+12v) ignition switch wire
6.) black/white - left speaker
7.) blue/white - ?? Has +12v when ignition is on
8.) orange/black - ????
9.) pink - (+12v) constant
10.) brown - right speakers
11.) black - ground or (-)right speakers
12.) white - right speakers
13.) white/black. - right speakers
Here is my aftermarket radio harness (for a pioneer stereo) and colors and what I found what wire is which.
1.) yellow - (+12v) constant
2.) red - (+12v) ignition switch
3.) green/black - (-) left rear speaker
4.) green - (+) left rear speaker
5.) purple/black - (-) right rear speaker
6.) purple - (+) right rear speaker
7.) gray - (+) right front speaker
8.) gray/black (-) right front speaker
9.) white - (+) left front speaker
10.) white/black - (-) left front speaker
11.) blue/white - ??
12.) black - (-) ground
Are these correct?? Am I good to just connect them?? Any help or ideas I can do
JeepingShtHpns is offline
post #2 of 13 Old 11-01-2013, 08:19 AM
Que89YJ
Que89YJ is offline
post #3 of 13 Old 11-01-2013, 03:07 PM
irnmadn88
I have a complete set of FSM's for the 88…
I have to run to do some stuff and will be gone for a couple of hours. Some time later tonight I will be able to get back to this.
irnmadn88 is offline
post #4 of 13 Old 11-01-2013, 03:19 PM
Que89YJ
It is pretty strait forward. No trick. It's an easy install.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 13 Old 11-01-2013, 03:24 PM
jbolty
jbolty's Avatar
save a headache and just run new speaker wires. You only need about 8 feet.
jbolty is offline
post #6 of 13 Old 11-01-2013, 05:41 PM
irnmadn88
1.) black - ground or (-)left speakers ***
2.) brown/white - left speakers Left Rear Return - Terminal B Left Speaker
3.) green - left speakers Left Front Feed - Terminal A Left Speaker
4.) green/white - left speakers Left Rear Feed - Terminal A Left Speaker
5.) purple/white - (+12v) ignition switch wire Connects to Cigar Lighter - Ignition
6.) black/white - left speaker Left Front Return - Terminal B Left Speaker
7.) blue/white - ?? Has +12v when ignition is on Goes to pin 3 on Radio Illumination Relay - Panel Illumination
8.) orange/black - ???? Goes to pin 5 on Radio Illumination Relay - Dim Display Signal
9.) pink - (+12v) constant Connects to Dome/Courtesy Fuse - Battery Memory
10.) brown - right speakers Right Rear Return - Terminal B Right Speaker
11.) black - ground or (-)right speakers ***
12.) white - right speakers Right Rear Feed - Terminal A Right Speaker
13.) white/black. - right speakers Right Front Feed - Terminal A Right Speaker
*** #1 or #11 are either Radio Ground OR Right Front Return - Terminal B Right Speaker
post #7 of 13 Old 11-01-2013, 06:02 PM
Chrisnvegas
Chrisnvegas's Avatar
In the future there is no need to butch the wires. There are cheap adapter plugs that plug right into the harness and you just match colors to the new radio.
My Jeep is NOT a Fiat!
Chrisnvegas is offline
post #8 of 13 Old 11-01-2013, 07:00 PM
irnmadn88
That is if you aren't fixing someone else's hack job. Been there done that.
post #9 of 13 Old 11-01-2013, 11:59 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
My advice ditch all the speaker wires from the head unit and factory harness. Hook the head unit to the constant power, switched power and the ground. Get a decent 4ch amp and use it to power the speakers it'll sound much better.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #10 of 13 Old 11-03-2013, 06:19 PM Thread Starter
JeepingShtHpns
Originally Posted by irnmadn88
These are the wires I have to work with coming from the jeeps harness. There is 13 and I numbered them from left to right. And what I THINK the wire is. 1.) black - ground or (-)left speakers *** 2.) brown/white - left speakers Left Rear Return - Terminal B Left Speaker 3.) green - left speakers Left Front Feed - Terminal A Left Speaker 4.) green/white - left speakers Left Rear Feed - Terminal A Left Speaker 5.) purple/white - (+12v) ignition switch wire Connects to Cigar Lighter - Ignition 6.) black/white - left speaker Left Front Return - Terminal B Left Speaker 7.) blue/white - ?? Has +12v when ignition is on Goes to pin 3 on Radio Illumination Relay - Panel Illumination 8.) orange/black - ???? Goes to pin 5 on Radio Illumination Relay - Dim Display Signal 9.) pink - (+12v) constant Connects to Dome/Courtesy Fuse - Battery Memory 10.) brown - right speakers Right Rear Return - Terminal B Right Speaker 11.) black - ground or (-)right speakers *** 12.) white - right speakers Right Rear Feed - Terminal A Right Speaker 13.) white/black. - right speakers Right Front Feed - Terminal A Right Speaker *** #1 or #11 are either Radio Ground OR Right Front Return - Terminal B Right Speaker
Thank you guys! This was the correct hook ups now my radio works perfect.
post #11 of 13 Old 02-02-2016, 12:42 PM
bhartwell59
1987 YJ Wrangler
THANK YOU!
The radio wiring in FSM (first DropBox link) worked like a charm! I just couldn't figure out the few YJ coded harness wires I had and where they went. Tunes for the first time in 3 yrs!
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #12 of 13 Old 08-16-2016, 07:42 AM
BobbyWagoneer
Does anyone know where I can get an original Jeep radio or one that looks like the original for a 1988 Jeep Grand Cherokee? I checked out the Custom Autosound USA-4 and that looked pretty cool. Thanks in advance.
BobbyWagoneer is offline
post #13 of 13 Old 08-16-2016, 08:49 AM
Que89YJ
Que89YJ is offline
electrical , help needed , radio , wiring , YJ
