88 YJ lower windshield brackets - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 88 YJ lower windshield brackets
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCCOR is your 1 stop source for everything Jeep!
Unread 01-26-2015, 04:00 PM   #1
robnor1
Lowered my windshield yesterday to install new wiper motor. I took off the bottom windshield brackets inside the jeep. Three torx screws each. Two on the top of the bracket and one at the bottom of the bracket. Problem is I cant get the bottom screws to go back in. Its like there are no threads in there for them to connect to. I cant see any way to get behind the panel without taking the whole dash out. Anyone run in to this before? Top two went back in fine. Thanks
robnor1 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 04:07 PM   #2
jbolty
jbolty's Avatar
the lower part of the hinge, the portion bolted to the tub, has nuts on the inside. You're lucky to have gotten them out without a fight but chances are they slipped out of place. They are just normal nuts but there is usually a huge blob of seam sealer covering them.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 09:49 PM   #3
robnor1
We are talking about the brackets on the inside of the Jeep not the actual hinges on the outside, right?
Unread 01-27-2015, 07:35 AM   #4
jbolty
jbolty's Avatar
I talking about the hinge but just realized you said brackets.
These? I never examined them but maybe there is a similar design and I bet there is a threaded plate floating inside the windshield frame.
