88 YJ Doesn't Want to Shift Into Gear - JeepForum.com
post #1 of 2 Old 06-22-2001, 09:19 PM Thread Starter
acejeep
First thing in the morning it doesn't want to shift into gear, no grinding, just doesn't want to go into any gear. Don't dare force it, (I know its a crappy tranny). After a while it'll slip into a higher gear only then will it go into first or reverse. Just started this week. Also while on the road it does shift as smoothe as it should.
What can I do ?
Knowledge is what we get from reading the directions.
Experience is what we receive from not reading the directions.
acejeep is offline
post #2 of 2 Old 06-23-2001, 10:59 AM
Ferrisbeu
Did you recently change your fluid to a heavier one? I put 80-120 in mine a while back and it wouldn't shift into 2nd until it warmed up. Try draining it and putting new 90 weight. I have an 88 w/ a Pugeuot tranny. Dont know a whole lot about trannys though. Search through the Quadratec BBS also for clues or post a message there also if you havent yet.
88 red YJ, 258 5 speed, 1" body lift, Pro Comp 3000 shocks, Alpine stereo til it gets stolen. Bunch of other stuff pending
Ferrisbeu is offline
JKS BL & Gear shift kaybone TJ Wrangler Technical Forum 9 07-02-2009 09:19 AM
Won't shift into gear with car on rdepetris YJ Wrangler Technical Forum 4 05-05-2009 03:16 PM
Won't shift into 1st gear sometimes ralphie762 TJ Wrangler Technical Forum 7 04-19-2009 10:09 AM
97 TJ doesn't want to shift into 1st gear Morgan_TJ Wrangler General Discussion 0 07-29-2008 11:43 AM
Can NOT shift into any gear!!! 98kkk TJ Wrangler Technical Forum 14 03-08-2006 11:54 PM
